MOSNet vs. MiamiDX
    dIGIMAN
    Posts: 273 from 2005/11/7
    Hi guys,
    i would like mention and maybe solve a problem once more.
    I am unable to get NFSD running with MOSNet,
    with MiamiDX, its no problem at all.
    I would stick to MiamiDX, but Samba is much more stable for me with MOSNet.
    NFSD requires a running portmap from Amitcp.
    If you start NFSD after Portmap with MOSNet,
    Portmap goes in suspended mode at once.
    With Miami, this doesnt happen.
    Somebody have an idea here? Im getting nuts.
    Dont want to keep a pc running, just because i cant serve NFSD right with Monset.
    Thanks in advance
  • »18.03.07 - 08:49
    GK_LKA
    Posts: 481 from 2004/3/28
    I am in a similar situation: I can't get Apache working with MOSnet. I have to use MiamiDX...
    [ GK / LKA Team ]
  • »18.03.07 - 09:29
    dIGIMAN
    That works fine for me, im running it in INETD Mode.
  • »18.03.07 - 09:57
    GK_LKA
    Ok, can you tell meg how to set inetd? I think you are using the inetd server from the AmiTCP archive. (Which version?)
    [ GK / LKA Team ]
  • »18.03.07 - 15:47
    dIGIMAN
    http stream tcp nowait root Apache:bin/httpd
    Thats the line of the inetd.conf
    AmiTCP/IP_inetd 4.7 (13.02.1996)
    Is the Version String, its from the AmiTCP 4.3 Package.
  • »18.03.07 - 17:22
    GK_LKA
    Same settings here and not working. Which Apache version do you use?
    [ GK / LKA Team ]
  • »19.03.07 - 10:17
    dIGIMAN
    Cant look for exact version atm, the machine seems to be down.
    But its one of djbase's compiles of apache. I think without php.
    But i will switch again to another version, as that one seems to generate alot of hits, atleast in inetd mode.
    Are you sure, u didnt miss some config line, in httpd.conf or something?
    It has to be configurated for inetd mode.
    It may still be in stand alone mode.
    @all:
    Nobody who can help me with portmap(nfsd) and MOSNet? :(
  • »19.03.07 - 10:25
    Framiga
    Posts: 363 from 2003/7/11
    [ Edited by Framiga on 2007/3/20 19:25 ]
  • »19.03.07 - 10:39
    Jupp3
    Posts: 1193 from 2003/2/24
    For me it was an easy decision...
    Random network data corruption on "above average" network load:
    MiamiDX: YES
    MOSNet: NO
  • »20.03.07 - 10:49
    GK_LKA
    Yes, that's the reason why I want to change too.. (And maybe some speedup, 'cause I have full duplex 100mbit internet connection... ;) )
    Apache works fine with it:
    MiamiDX: YES (since 2001)
    MOSnet: NO (it doesn't start at all or is unstable)
    [ GK / LKA Team ]
  • »20.03.07 - 11:43
    dIGIMAN
    MiamiDX: YES
    MOSNet: NO
    Yeah but i cant live without portmap/NFSD, so i have to switch between mosnet and miami, depending what i want.
    This is quite anoying :/
  • »20.03.07 - 13:00
    amiga4001
    Posts: 452 from 2006/11/16
    I am trying Mosnet now instead off miamidx.
    Much more speed with Ibrowse.
    But mldonkey refuses to work with it.
    Is this some setting/config which is wrong/missing?
  • »21.03.07 - 17:54
    dIGIMAN
    this somehow sounds a bit like a usergroup library problem.
    Have u set up all there? What happends when you start?
    Well, to bad its not the problem on my side dawn it.
    Maybe i should try amitcp again :)
  • »22.03.07 - 06:02
    amiga4001
    How do I set up this usergroup lib?
    Never setted anythinh with miamidx worked out off the box.
    comment with mldonkey:
    The core is unable to get Edonkey serverlists and loading
    torrent files via dllink from websites is also impossible.
    If you are using MLdonkey in a chroot eviroment you should consider reading this article to get dns support back....
    Have found the usergroup.lib on aminet.
    installed but same error.
    [ Edited by amiga4001 on 2007/3/22 19:26 ]
  • »22.03.07 - 16:46
    MarK
    Posts: 641 from 2004/1/25
    well, when talking about speed issues, why is my dnetc download/upload so slow under mosnet, and so fast under miamidx? and why is mosnet so cpu hungry during download? i get about 30-40% cpu load when downloading via mosnet, and almost nothing with miamidx...
    bye, MarK.
  • »23.03.07 - 06:56
    amiga4001
    To me it seems mosnet is much faster then miamidx.
    That is on a pegasos2.
    Now I noticed not only mldonkey refuses to work but also sputnik doesn't start up.
    It complains it wants usergroup.lib ver 0.
    Is there a workaround for this usergroup lib thing?
  • »23.03.07 - 19:40
    dIGIMAN
    If u ask me, it looks like u have an old usergroup.library somewere
    wich is loaded first
    Compare the Usergroup Library in Memory with the Version String of the
    Mosnet One.
    usergroup.library 4.5 (15.12.2005)
  • »24.03.07 - 01:31
    dIGIMAN
    Cant somebody, with an working User/Group enviroment under MOSNet
    try if Portmap+nfsd works for him?
    This would help me to find out, if its a configuration problem
    or a problem with the stack.
    Run Portmap from Amitcp
    If u dont have it, the demo version on aminet is enough
    Ofcourse its necessary, that the assigns (amitcp) are right.
    After that, run the nfsd daemon:
    http://www.kafsemo.org/nfsd/
    When u configrate it right, which is easy to do,
    it should start up.
    Now please check if portmap is suspended/crash with scout
    This alwasy happends with my setup, but only under MOSNet.
    This shouldnt take to long to check,
    and u will know u could also use a digital settop
    box for streaming TV, like me :))
  • »24.03.07 - 01:40
    amiga4001
    Working now.
    I had to copy the usergroup.lib to libs:
    Strange that the installer din't did this.
  • »24.03.07 - 11:02
