SView5 v2.21 (17.3.07) released
  • akl
    akl
    Posts: 10 from 2004/7/31
    You can download the .readme and .lha from here:
    http://www.ar-kleinert.de/download.html
    Also on Aminet (soon).
    [ Edited by akl on 2007/3/17 13:01 ]
  • »21.01.07 - 14:32
  • akl
    akl
    [ Edited by akl on 2007/2/9 11:18 ]
  • »04.02.07 - 16:04
    antibike
    Posts: 112 from 2003/3/5
    i can't find morphos executables
  • »04.02.07 - 17:29
  • akl
    akl
    There are specific .elf loader/saver modules for MorphOS.
    Currently namely these are:
    PNG, JPEG, GIF, JPEG2000, TIFF.
    I'm still undecided which ones should follow next, since a native .elf module does not always cause a significant speed gain - because the MOS 68k JIT delivers quite good results. On the other hand, maintenance of each additional modules causes additional (testing) overhead for the programmer. So a trade-off needs to be done.
    [ Edited by akl on 2007/2/9 11:21 ]
  • »04.02.07 - 18:20
  • akl
    akl
  • »04.02.07 - 18:21
  • akl
    akl
  • »17.03.07 - 17:53
