misaligned textinput fields in MUI apps
    Amigaz
    Posts: 121 from 2005/6/11
    Only the middle part is used and seen in my textinput fields on my MUI
    apps like Ibrowse 2.4 for example...is there a cure?
    MorphOS PowerUP powered Amiga 4000
    Pegasos II G4 1ghz
    Radeon 8500 128mb
    Soundblaster Live 5.1 Digital
    Realtek 2139B 100mbit
  • »11.03.07 - 10:08
    Jupp3
    Posts: 1193 from 2003/2/24
    MUI settings, String, Container, adjust spacing by dragging numbers in Spacing-rectangle (top left of the window)
  • »11.03.07 - 11:24
    Amigaz
    It worked
    Thanks
    (sometimes the solution is too simple) :-)
    Pegasos II G4 1ghz
    Radeon 8500 128mb
  • »11.03.07 - 12:08
    Jupp3
    The thing is, it's not a bug - it's a feature :-)
  • »11.03.07 - 15:47
