Frying pan not starting
    amiga4001
    Posts: 454 from 2006/11/16
    I just downloaded Fpan1.1 and it works great and is fully registered.
    But when shutdown and try to restart I get a unable to open application.
    A reboot only doesn't cure this have to shut the peg down and restart.
    Anybody else with same symptoms?
  • »29.01.07 - 18:51
    Posts: 1087 from 2003/3/24
    Nope everything's fine here!
  • »29.01.07 - 21:46
    merko
    Posts: 328 from 2003/5/19
    Sounds like a MUI related problem. What MUI version do you run? Works
    fine with default MOS 1.4.5 MUI here.
  • »30.01.07 - 01:42
    amiga4001
    Mui 4.
    I see in Snoopdos it is unable to make dir ENVARC:Frying PAN and also ENV:FryingPAN.
    Maybe thi is the cause?
  • »30.01.07 - 04:15
    Motosampy
    Posts: 199 from 2004/8/14
    You should already have ENVARC:FryingPan dir and that's why it cannot be created, that shouldn't be the cause to your problem.
  • »30.01.07 - 09:13
    beanbandit
    Posts: 50 from 2006/4/19
    1) reboot (just reset not hard reset)
    2) increase the stack size (try with some high value, like
    200,000) (the icon probably has some stupid value like 4096)
  • »30.01.07 - 15:31
    Posts: 1521 from 2003/2/24
    @beanbandit
    It doesnt matter. In MorphOS 1.4 68k programs always get 16kB 68k stack and 32kB PPC stack as a minimum. It should work with 4kB stack too...
    @amiga4001
    I just downloaded Fpan1.1 and it works great and is fully registered. But when shutdown and try to restart I get a unable to open application.
    I suppose FP trashed random memory or something...
    [ Edited by itix on 2007/1/30 19:41 ]
  • »30.01.07 - 15:41
    Seems there is a bug in FryingPan. I ran FP with Wipeout and got 0xdeadf00d hit from PROGDIR:LIBS/MUI.interface. It suggests FP has got an uninitialized variable somewhere...
  • »30.01.07 - 15:56
    beanbandit
    @Itix
    well all I know is that
    1) if I run FryingPan with the default Stack in either shell or
    Icon, then it will not start. period.
    2) If I raise it to for instance 200,000 then it will always start
    without any problems.
  • »30.01.07 - 18:16
    amiga4001
    I reinstalled Fpan 1.0a works ok.
    Will try this stack issue to get 1.1 going.
  • »30.01.07 - 18:40
    FLComputer
    Posts: 22 from 2005/9/26
    Hi all ;)
    I've tested it here with Mui 4 from september 2006 and latest ambient build, no problems of starting it or restarting it.
    Thanks to Tom for his great job ;)
    Faranheit - F.L. Computer
    I.M.M. Informatique : YOUR Efika Reseller for France, Luxembourg and Belgium !
    Mail : laurentz@informatique-imm.lu
    Site : http://www.informatique-imm.lu
    ICQ : 81617715
    Skype : faranheit57
  • »31.01.07 - 09:57
    Posts: 108 from 2005/4/3
    Hi all,
    Mostly FP 1.1 starts, but sometimes it won't start. I try to use 200000
    stack in the icon.
    Grts, Amigaharry
    http://www.angelfire.com/amiga/ex
  • »31.01.07 - 16:32
    MarK
    Posts: 641 from 2004/1/25
    mine started right after the instalation without any troubles... tried more times... also without any trbls...
    bye, MarK.
  • »01.02.07 - 10:36
    amiga4001
    Installed the newest release off Fpan.
    Workes ok but not for formatting off CD RW somehow.
    I am doing that with make cd now.
    Fpan freezes on this or gives a track layout error.
    Known issue?
  • »10.03.07 - 19:28
