MorphOS Developer
Posts: 619 from 2005/8/27
I resist to admit that my G3 is totally unable to play commercial DVDs with the FABulous MPlayer, and I wanted to try every possible trick to accomplish it.
As of now, I've been only able to play DVDs nicely, but with sound disabled.
Well, unfortunately I can tell you that you can probably forget about that for now (or atleast until (if ever) the MorphOS version of MPlayer is rewritten (don't expect this to happen)), the reason is outlined somewhere else here on MZ atleast twice by me (search for it)...
Recently, I was told that it's wise to configure AHI for it not to resample the audio coming from DVD source, as it eats precious resources. What should I do?
You don't have to worry about that unless you use the ahi_dev output (which isn't the default afaik), in which case all you have to do is configure Unit 0 as a 16bit ++ mode at 48kHz (which btw, will cause other apps using this unit with other frequencies to resample, so beware)...
I already have the latest AHI update from the MorphOS FTP.
You should get the official update
here instead...
- CISC
