SSH server for MorphOS?
    GK_LKA
    Posts: 481 from 2004/3/28
    Is there any SSH server for MOS available? Or is it possible to port one at all? I need it to easily copy/move/download files when I'm not at home with low bandwidth.
    [ GK / LKA Team ]
  • »25.02.07 - 21:36
    CISC
    Posts: 619 from 2005/8/27
    Then surely what you're asking for is sftp-server (or why not just plain ftp server?), which should build more or less OOTB (you need to tweak some settings to disable root-check etc), though I'm not sure what low bandwidth has to do with SSH (maybe I misunderstood the question)?
    - CISC
  • »25.02.07 - 22:33
    GK_LKA
    I mean remote downloading files with my Pegasos from net ;), but there are a lot of other commandline tools which I like to use when I'm away.
    [ GK / LKA Team ]
  • »25.02.07 - 22:57
    Kamul
    Posts: 121 from 2004/6/9
    Maybe GK_LKA wanted to say, that things like VNC can't be used because of low bandwitdh.
  • »26.02.07 - 06:45
