new logtool released
    MarK
    Posts: 641 from 2004/1/25
    great, that the new version of logtool has just been released! i just wonder, if it is possible to catch also the 68k hits only.
    link: logtool website
    anyway, great, that there is some progress! please go on!
    bye, MarK.
  • »13.02.07 - 10:02
    Framiga
    Posts: 363 from 2003/7/11
  • »13.02.07 - 11:24
    Posts: 3327 from 2003/3/5
    No, it's not possible to catch 68k hits separately. Expect a fully features logtool 2.0 in about a month.
  • »15.02.07 - 12:03
    MarK
    okay then... so is it possible to filter all the other hits out? to be able to read only 68k filters?
    bye, MarK.
    btw: how about to add some sort of disassembler for the crashed code?
  • »16.02.07 - 06:08
    Well... I guess you could filter non-68k hits with the current filtering system...
    As for a disassembled - that's planned for 2.0, yea. Dunno if you noticed 2.01a displays file/line of the hit if possible.
  • »16.02.07 - 08:26
    igracki
    Posts: 469 from 2003/2/24
    how about a search feature?
    That would be cool!
    And cursor support to scroll up/down in the list.
    And could it be possible to specify/load the "unstripped binary" AFTER the hit occured to analyze the hit afterwards?
    And sometimes logtool doesn't saves the contents of the process-names stringgadgets, when I use "*".
    BTW:
    I still have to figure out why I get a "Please insert con" at startup;-)
    I didn't get it, when I use the PowerTerm.mcc v50.55 and MUICON-Handler v50.21...
  • »16.02.07 - 15:47
    Search is planned of course. I wonder why I didn't add it yet since muicon/sshcon have it ;)
    will consider the rest of your requesrs too of course.
    As for the "Please insert" requester, see the PM :)
  • »16.02.07 - 19:00
    MarK
    would it be possible to display also the catched guru meditation description? my application made system error 4... and it took me several minutes, until i found, that it's an illegal instruction call :-)
    bye, MarK.
  • »19.02.07 - 04:39
    Henes
    Posts: 507 from 2003/6/14
    Because you didn't RTFM enough ;-)
  • »19.02.07 - 19:46
    MarK
    ;-) i did... but several years ago... :-P
    bye, MarK.
  • »21.02.07 - 04:13
    OK, another logTool2 build is available for download in the usual place. Make sure you update PowerTerm too, I finally fixed the busyloop that sometimes happened to some of you while using logTool.
  • »21.02.07 - 18:53
