IBrowse 2.4 released
    Framiga
    Posts: 363 from 2003/7/11
    mhhh!
    i have on a PowerUP system (4Mb connection):
    10 Max Connections
    4 Max simultaneous doenloads (important)
    then in Prefs>Cache Min.ChipMem to OFF
    and then try to disable gzip/daflate also (not sure if could bangs with latest Ambient/MUI4) in Network
  • »24.12.06 - 13:03
    AmigaMancer
    Posts: 265 from 2005/8/25
    I see that ppl with classic Amigas can run IB2.4. How do you do it? By disabling Trance or by doing some other trick?
    Amiga 1200 user.
  • »25.12.06 - 00:06
    Amigaz
    Posts: 121 from 2005/6/11
    Wanna know too  :-D
    MorphOS PowerUP powered Amiga 4000
    Pegasos II G4 1ghz
    Radeon 8500 128mb
    Soundblaster Live 5.1 Digital
    Realtek 2139B 100mbit
  • »25.12.06 - 10:27
    Velcro_SP
    Posts: 929 from 2003/7/13
    [ Edited by Velcro_SP 27.07.2011 - 13:12 ]
    Pegasos2 G3, 512 megs RAM
  • »25.12.06 - 10:51
    Framiga
    Velcro_SP.... its Trance the problem and us with MOS for PowerUP can't (i've registered months ago to the support site without ANY reply) download the latest one.
    Although some of us "poor" PowerUP users, have helped a LOT of other users to get MOS for PowerUP running.
    But, as you know... "life sucks"! ;-)
  • »25.12.06 - 11:44
    Framiga
    very nice Ken! Thanks :-)
  • »26.12.06 - 10:50
    cecilia
    Posts: 459 from 2003/8/30
    sadddam wrote:
    i have the same pink colors in my toolbar:
    and i have another problem with ib2.4: cannot open the settings window. ......
    I installed 2.4 on my peg and while I also get the pink colors I can get the settings window to open.
    however, on my WinUAE OS3.9 system I cannot open the settings window. it just hangs there like dead. the mui files were changed (I used the iBrowse 68k version).
    I still kept my 2.3 IBrowse on WinUAE and I can get the Settings window to open on that version.
    I'm not sure what the heck the problem is, but if I ever figure it out, i'll let you know.
    iB looks nice, in any case!
  • »20.02.07 - 16:43
    Posts: 2215 from 2003/2/24
    I noticed that settings window hangs on too small screenmode.. like on my A1200/030/AGA it hangs with 640x256, but works with 640x512 ;) But I guess nobody uses WinUAE with that small resolutions :)
  • »21.02.07 - 15:45
