poseidon & samsung yp-f1 player
    Korni
    Posts: 473 from 2006/2/23
    I just bought it, but it doesn't work with poseidon. I get "warning massstorage.class ignoring automounting request: Blocksize 2048 bytes (cd or dvd?) :(
    I have latest Poseidon for MorphOS1.4.5.
    I tried fat from march too.
    Maybe access to mp3player is possible through Linux?
    [ Edited by Korni on 2007/2/20 15:56 ]
  • »20.02.07 - 12:05
    Posts: 1082 from 2003/3/24
    You should write an email to Chris Hodges he will help you.
  • »20.02.07 - 13:42
    Korni
    Problem solved. Partially. I use classes from latest 68k release. I set simple SCSI and No Initial reset. Now it works!!1 But only with march's FAT w/o write support :)
  • »20.02.07 - 13:57
