vnc
    klapdeur
    Posts: 132 from 2003/6/28
    Hi guys i've a problem with vnc (morphvnc as twin vnc)
    i cant connect to my windowws xp machine why i don't know.
    from xp to mos (with server works).
    can anyone help me out here?
    Greetz
    klapdeur
    P?oblem solved thnx guys was a xp problem
    [ Edited by klapdeur on 2007/2/18 19:38 ]
  • »18.02.07 - 16:17
    SoundSquare
    Posts: 1213 from 2004/12/1
    please provide more information
    - what happens when you call the vnc server on your windows XP ? any message, error ?
    - what VNC server do you run on XP ?
    - do you have a firewall ? a routeur ? is the VNC port opened ?
    [ Edited by SoundSquare on 2007/2/18 18:04 ]
  • »18.02.07 - 17:04
    GK_LKA
    Posts: 481 from 2004/3/28
    Yes, we need some more information... For an alternative I can suggest you to try RDesktop (Windows Remote Desktop service)! IMHO it's much better than VNC on XP.
    [ GK / LKA Team ]
  • »18.02.07 - 17:19
    Framiga
    Posts: 363 from 2003/7/11
    but you need XP Pro! how about Home users?
    I've downloaded a RDP server for the Home edition WinConnect-ServerXP (7 days trial period) but it costs 299 US$!!! heck a little too much for my needs.
    Any suggestion of a free or cheaper winXP Home RDP server?
    Thanks!
    [ Edited by Framiga on 2007/2/18 19:31 ]
  • »18.02.07 - 18:15
    magnetic
    Posts: 2129 from 2003/3/1
    Yes, your windows must support it. I used to connect to my XP Pro box wtih my peg/mos. Will we be able to connect to Vista soon? (Hammer??)
    magnetic
  • »18.02.07 - 19:42
    judas
    Posts: 175 from 2005/1/14
    You must check and disable any firewall-settings on XP. Otherwise you cannot connect from the outside to the vnc-server
  • »18.02.07 - 19:56
    GK_LKA
    Hm... I've never used XP Home, sorry, but I think it has the RDP server feature, it's just disabled somehow (maybe registry?). Sorry, I can't give you more information, since I don't use W!ndows (only a pre-configured school-server via RDesktop), and it's maybe not the place to discuss how to set your XP-box ;)
    [ GK / LKA Team ]
  • »19.02.07 - 11:00
    Framiga
    why not? probably not all the users owns XP pro (there are some "hacks" -see as tweak with components and registry- on the net to turn on the RDP server even on the home edition)
    like this and ... oops just removed due msoft request :-/
    Anyway your right....probably not the right place! :-)
  • »19.02.07 - 11:33
