Posts: 452 from 2006/11/16
Too bad can't get it going for now.
Changed all settings too see if it would go but to no avail.
Nice program this Ptp proggie thanks for link.
I'll have too get me a memory stick and see if it will go then.
Strange everything else I tried worked out off the box like:
An other cheap camera,usb stick,mouses,joystick adapters.
I've send an email to chris hodges so maybe he has a tip.
Installed a memorystick into the camera.(they are very expensive!) and workes ok now!
Guess the internal memory works different then the stick.
Too bad this ptp program doesn't work with it looked nice.
Only bad thing now this camera eats battery's for breakfast.
Did see 2700 Mah battery's got to invest again I think.
[ Edited by amiga4001 on 2007/2/17 20:14 ]
