printer settings saved where in morphos
    amiga4001
    Posts: 452 from 2006/11/16
    Just tried to print with yam with a laserjet4 to see off that would work...no.
    But now I can't go back to my old settings.(usb epson)
    It just won't save my setings.
    I removed the laserjet4 but it still is coming up as installed under the printericon in the configuration window.
    Where does morphos saves his settings off the system?
    So I can delete it and try again.
  • »09.02.07 - 05:47
    Ingo
    Posts: 103 from 2004/3/19
    sys:Prefs/env-archive/sys/
    turboprint:configs/
    You should probably reboot when you delete the settings.
  • »09.02.07 - 14:08
