Mplayer own Screenmode
    Posts: 1087 from 2003/3/24
    Is it possible to force mplayer to open a movie on a predefined screenmode in fullscreen, not the same resolution like ambient?
  • »08.02.07 - 13:47
  • Fab
    Fab
    Posts: 1331 from 2003/6/16
    Yes you can,
    mplayer -vo <videodriver name>::MODEID=<modeid hex value>
    So for instance, mplayer -vo cgx_overlay::MODEID=0x40920053 <your file>
    You can use getmodeid from aminet to know the modeids for a given resolution.
  • »08.02.07 - 16:24
    Norbi
    Posts: 99 from 2004/6/19
    Or ScreenMode -> Edit Screen
  • »08.02.07 - 17:11
    Korni
    Posts: 473 from 2006/2/23
    Or GetModeID from PicShow archive :)
  • »08.02.07 - 17:27
    Can i use this in the popupmenu of the new Ambient?
  • »08.02.07 - 20:40
  • Fab
    Fab
    If you mean the contextmenu depending on filetype, sure, you can. Just modify the action for your video filetypes accordingly (and in case you don't know it, you can add actions for the whole video/* family, instead of adding them for every single video filetype).
  • »08.02.07 - 21:39
    Yeah i mean the contextmenu, and i know how modify it but i don't know the right syntax.
    Maybe someone could help me with an example.
  • »08.02.07 - 23:21
  • mk
    mk
    Posts: 72 from 2004/5/24
    many many "examples" (also for Mplayer):
    http://morphosambient.sourceforge.net/dl/Filetypes20061027.lha
    [ Edited by mk on 2007/2/9 8:00 ]
  • »09.02.07 - 04:59
    I use this command: Run >nil: `type env:pathapp/mplayerRC1` %sp -vo cgx_overlay::MODEID=1083310162
    But MPlayer still opens a window in Ambient no screen.
    [ Edited by ThePlayer on 2007/2/9 9:59 ]
  • »09.02.07 - 06:50
  • Fab
    Fab
    Well, first MODEID doesn't accept decimal values ATM, but only hexadecimal (ok it's lame:)). Secondly if you want to start directly in fullscreen mode, then add -fs
  • »09.02.07 - 09:51
    And how do i get the hexadecimal values?
    And if i add -fs at the end of line mplayer opens in FS but my TFT is going black and nothing happens.
  • »09.02.07 - 12:29
  • Fab
    Fab
    Well, getmodeid from aminet returns the hexadecimal value (0xsomething). Otherwise take your favorite calculator and convert your decimal value to an hex value. :)
  • »09.02.07 - 12:37
    Thank you now it works! :-D
    And keep up the FABulous work you do on Ambient and the rest of the Ambient Team.
    PS: One question: Is it possible to compile Ambient with a higher icon max size like 96x96?
  • »09.02.07 - 13:49
