muicon & new PowerTerm
  • rms
    rms
    Posts: 606 from 2004/11/27
    Hi all,
    I have installed the new muicon version from yesterday as well as the PowerTerm v50.68 (14.01.2007) and now MUI (16.06.06) crashes as soon as I select PowerTerm in MUI prefs.
    Does anyone else have this problem?
    Regards
    Christoph
  • »18.01.07 - 05:38
    Otti
    Posts: 20 from 2004/3/31
    Same Problem here, going with mouse over the Powerterm part MUI freezes.
    Its not possible to start it again, reboot is needed.. :(
  • »18.01.07 - 08:33
    tokai
    Posts: 1289 from 2003/2/25
    Well.. I didn't tried the new stuff myself.
    Here a few things you might wanna try:
    Check with SnoopDOS what it tries to open when you select the prefsitem, maybe just something is missing and there is a poor error handling (wouldn't be the first time for jaca AFAIR ;) ). Make sure you have installed all requirements, see the manual/readme/whatever.
    If that doesn't help, please send an mail to the author (or maybe post here) the full hits from the debug log. This might offer further information about the crash.
    regards,
    tokai
  • »18.01.07 - 08:41
    weiseb
    Posts: 215 from 2003/3/29
    Did you install the latest iconv.library (2.1)? The one that came with Sputnik is too old. http://www.binaryriot.org/dreamolers/sshcon/index.php?func=DOWNLOAD
  • »18.01.07 - 10:03
    Framiga
    Posts: 363 from 2003/7/11
    Thanks weiseb. the newer iconv.library fixed the problem.
  • »18.01.07 - 10:53
    Framiga
    @tokai
    if you still need the logtool output (before changing the iconv.library) you can find here in the MosDepot :-D (joking obviously)
    /me runs
    Edited...
    [ Edited by Framiga on 2007/1/18 14:02 ]
  • »18.01.07 - 10:58
  • rms
    rms
    YES this did it, thanks for your advise :)
    Regards
    Christoph
  • »18.01.07 - 15:07
    Framiga
    tokai wrote:
    @framiga: I prefer raw ramdebug/ serial log output. logtool stuff is for sissies. ;)
    ops sorry tokay, i thought you were! :-)
  • »18.01.07 - 16:06
    AmigaMancer
    Posts: 265 from 2005/8/25
    Sorry for the off topic but i saw in the link which was posted by weiseb, that there is an ixemul.library version 49.20. I know from personal experience that v49.19 had a serious bug which made several apps to stop working. At least the 68k one, but from what i read, MOS version was also bugged.
    Is this version fixed or should i continue to use v49.18?
    Amiga 1200 user.
  • »18.01.07 - 16:35
    Brumiga
    Posts: 276 from 2004/4/3
    Good evening,
    I have installed the latest muicon, it works but without locale. Via SnoopDos I saw that muicon-handler loads the catalogs correctly but the items do not appear in the locale, french for me. Are not the catalogs to old ? They are 2 years old, that is enormous ! Were the translators asked to release new catalogs or will they be ?
    Brumiga
  • »18.01.07 - 18:14
    Posts: 3327 from 2003/3/5
    The catalogs are old indeed. I have mentioned that they need to be updated in on of the updates. Too bad no translators seem interrested in doing so :/
  • »19.01.07 - 09:38
    hooligan
    Posts: 1948 from 2003/2/23
    I overwrote all files with the new ones, also updated latest iconv and rebooted. I cant type anything, I can mark+copy though. Any ideas?
    Windowgrab included.
     Attached file(s)
  • »19.01.07 - 12:50
    Posts: 126 from 2003/2/17
    oops I didn't know it needed update... french catalog WILL be updated sunday night...
    jo?l (who did the original french cat)
  • »19.01.07 - 19:19
    Now that's fun :/ Could you perhaps check if the fonts settings in PowerTerm prefs are correct?
  • »21.01.07 - 03:14
    hooligan
    Yeah, was tipped about this at #morphos. I tried several different fonts too, without help. Annoying :)
  • »22.01.07 - 02:21
    hooligan
    Strange. Now I installed earlier version of MuiCon (50.36) and when I start the shell I get:
    http://koti.phnet.fi/yh14756/muicon.jpg
    [ Edited by hooligan on 2007/2/3 12:57 ]
  • »03.02.07 - 08:56
    Pretty fancy :) Mixing new MUICON with old PowerTerm and vice versa will not work.
    Checked if you don't have font color settings messed up? :) Try picking rgb colors instead of pens.
    [ Edited by jacadcaps on 2007/2/3 23:24 ]
  • »03.02.07 - 20:23
    Furvert
    Posts: 83 from 2004/4/20
    The iconv.library and TTEngine no long seem available from the links given on this page. Are they still available?
  • »03.02.07 - 23:06
    I'll fix the URL on the new update. Sorry ;)
  • »04.02.07 - 08:05
    Bladerunner
    Posts: 418 from 2004/2/19
    Actually they are still available, unfortunatelly Aminet is currently half broken, so they have to use reduced service, which leads to some strange problems, like this one
  • »04.02.07 - 09:04
    Furvert
    Thanks for the help
  • »04.02.07 - 11:17
