YAM, newest build
    dIGIMAN
    Posts: 273 from 2005/11/7
    Hi Dudes,
    i have a problem with the l8st yam builds, maybe somebody has an idea, as im stucked.
    Since about a week the icons in the yam toolbar for read/wrinting mail are fully are trashed.
    The Toolbar Images themself are not broken.
    Ive switch to the newest YAM Builds and THE BAR MCC, since about then
    that happens. I didnt replace the icons images.
    Downgrading doesnt seem to help.
    Ive also noticed this in ramdebuglog:
    truecolour ReadPixelLine8() not supported
    Ofcourse it can also be caused by something else but i didnt changed much except:
    switch back to MiamiDX from MOSNet, coz of not working NFSD
    Using NFSD and Portmap for AMITCP.
    Thats all.
    Im stuck. Any ideas?
    Thanks,
    dIGIMAN
  • »26.01.07 - 13:30
  • rms
    rms
    Posts: 606 from 2004/11/27
    You have to switch back to the older version of TheBar.mcc as the new one v21.1 seems to be responsable for this and also to an older version of YAM of course. I use the one from 14.01.2007 which still works with old TheBar.mcc.
    BTW, I've seen on sourceforge.net that someone already notified the developpers about this problem under MorphOS.
    Regards
    Christoph
  • »26.01.07 - 13:51
    dIGIMAN
    rms wrote:
    Regards
    Christoph
    Ok Thanks for the information.
    I was afraid i trashed my configuration somewhere.
  • »26.01.07 - 14:12
  • Visitor
  • as workaround you can change all the icons from png to ilbm format.
    the bug/feature must be in the new 21.1 TheBar MCC, because if you change the images in the TheBar demo apps to png the images are also trashed. it is not a yam issue. i hope the developer read the bug report an can fix it soon.
  • »26.01.07 - 17:44
  • Visitor
  • this issue is fixed. download the fixed version here
    http://sourceforge.net/tracker/download.php?group_id=154192&atid=790794&file_id=213844&aid=1641342
    or wait for the next release :)
    [ Edited by antibike on 2007/2/2 9:52 ]
  • »01.02.07 - 14:50
    Posts: 1084 from 2003/3/24
    Do you know when the next release will come?
  • »01.02.07 - 16:18
  • Visitor
  • no i don't know.
    just download the fixed version.
  • »02.02.07 - 06:51
