Problem with Slider in Transpoclock
    weiseb
    Posts: 215 from 2003/3/29
    I am not able to set an Event(Alarm) in Transpoclock
    because I only get every other number with the slider
    (1,3,5..).
    The same for setting the time in system settings
    but I am using an atomic clock program for that anyway.
  • »13.01.07 - 10:36
    Motosampy
    Posts: 199 from 2004/8/14
    This seems to be a MUI4 problem, I get ony even numbers in every application that uses mui slider.
    I really dislike anyway the whole slider system, I prefer e.g. pulldown list. The best would be the style used in UIQ mobile phones (e.g. SonyEricsson P910i, M600i and P990i) with arrow adjusting for every number
  • »13.01.07 - 13:30
    Framiga
    Posts: 363 from 2003/7/11
    it could happens even on MUI 3.9 if the MUI app have a bu... oops sorry i was quite ready to write the evil word! i meant to say a "problem" ;-) (i'm speaking generally, NOT refereed to Transpoclock)
  • »13.01.07 - 14:18
    Posts: 1087 from 2003/3/24
    Try to deactivate mouse accelartion or set the mouse speed down!
    That should solve the problem.
  • »13.01.07 - 14:59
    weiseb
    @ThePlayer
    Thanks, its still hard set the values and I have to raise
    the mouse speed again to comfortably operate
    but it works!
  • »13.01.07 - 21:05
    Posts: 3327 from 2003/3/5
    Instad of changing the mouse speed, you can also use the mouse wheel.
  • »14.01.07 - 11:13
    weiseb
    Cool, thats a good solution.
  • »15.01.07 - 16:07
