DragIt for MOS?
    GK_LKA
    Posts: 481 from 2004/3/28
    I want to move my windows without dragging the titlebar, e.g. with pressing a qualifier key and dragging by clicking somewhere inside the window and move the mouse.
    It've found this program on aminet:
    http://aminet.net/package/util/wb/DragIt4
    This should be used exactly for this, but it seemed not to work on MOS. Is there any similar programs which works on MOS?
    [ GK / LKA Team ]
  • »30.12.06 - 09:41
    Furvert
    Posts: 83 from 2004/4/20
    You can go into System setting, IContol, Misc and set border clicking to use any border to size or drag windows.
  • »30.12.06 - 13:56
    GK_LKA
    I KNEW that somebody WILL answer this :D
    What I need is to drag windows *anywhere* by pressing some key. :)
    [ GK / LKA Team ]
  • »30.12.06 - 15:22
    Posts: 1521 from 2003/2/24
    MCP?
  • »30.12.06 - 16:08
    GK_LKA
    Seems not working on MOS and I couldn't find suck feature in MCP either.
    [ GK / LKA Team ]
  • »30.12.06 - 19:38
    pixie
    Posts: 148 from 2003/9/5
    Can u use this commodity straight on MorphOS?
    pixie - writing from a paradise called Portugal
  • »01.01.07 - 16:26
    Sure.
  • »01.01.07 - 22:37
    Posts: 2217 from 2003/2/24
    Well.. one program which could be tried is OpaqueMove. I don't know if it works on MOS and it has that opaquemove routine, if that causes troubles, but anyway it has good settings for qualifiers and ways to move the window... including that clicking anywhere in the window.
  • »02.01.07 - 10:41
