installer with mousewheel support
    amiga4001
    Posts: 445 from 2006/11/16
    I am using the installer from amiga os 3.9 now.
    Works ok but misses mousewheel support.
    Is there a better version available?
    Also can I use magic asl to go with it?
    Or is this a patch I shouldn't use.
  • »25.12.06 - 22:07
    analogkid
    Posts: 667 from 2004/11/3
    Recent MUI4 versions have an MUIfied ASL-requester, which is AFAIR based on MagicASL.
  • »26.12.06 - 04:08
    GK_LKA
    Posts: 481 from 2004/3/28
    I think you need this:
    http://aminet.net/package/util/sys/InstallerNG
    (MUI replacement of the original Commodore Installer)
    [ GK / LKA Team ]
  • »26.12.06 - 09:57
    amiga4001
    Yes that is the better more features on I meant.
    Only problem is It doesn't want to install on morphos.
    And only copying the installer(020+) is no good.
    Or is it missing something?
  • »26.12.06 - 19:02
    Posts: 423 from 2005/4/9
    i tried this. i could install it and succesfully use it to install some software. but it fails to install amissl v2 and aweb-lite, then i switched back to original installer, which was able to install those packages... well, i really liked installerng (its nice, has uninstall support, uses mui!:), but it seems installer works better and more compatible...
    hope we'll get a proper installer with mos 1.5 (if ever:)
    zx.spectrum@3.5
  • »27.12.06 - 01:20
    GK_LKA
    @saddam:
    Yes, you are right, it is not perfect :( For me it crashed a lot, so I switched back to the Commodore's Installer too. I think there is no better solution - you use the C= Installer and scroll with the scrollbar, or have troubles with this one :)
    [ GK / LKA Team ]
  • »27.12.06 - 12:15
