Trancestats doesn't work anymore
    AmigaMancer
    Posts: 265 from 2005/8/25
    Hi.
    I haven't tried to run this tool lately, but i just did and notice that it doesn't work. It used to work when i was using MUI 3.9 and the old Ambient but not now.
    It's not a big deal, i know that there are better tools than this, but i need to know if it doesn't work with the latest MUI 4 or if there is something is wrong with my installation.
    Amiga 1200 user.
  • »20.12.06 - 07:36
    Amigaz
    Posts: 121 from 2005/6/11
    Same prob here after installing MUI4 Alpha  :-x
    MorphOS PowerUP powered Amiga 4000
    Pegasos II G4 1ghz
    Radeon 8500 128mb
    Soundblaster Live 5.1 Digital
    Realtek 2139B 100mbit
  • »20.12.06 - 08:18
  • tom
    tom
    Posts: 149 from 2003/7/22
    it still works here without any problem. But after installing Mui4 alpha I have another problem. If I want to download something the requester opens, then my Pegasos slows down, especially when it is the first time since booting. After 3 or 4 seconds my Pegasos works normally again..
    Someone has any an idea why?
    regards Tom
  • »20.12.06 - 10:56
    Amigaz
    Seems like we who use MOS PUP are the only affected by it not working then....
    Pegasos II G4 1ghz
    Radeon 8500 128mb
  • »20.12.06 - 11:17
    AmigaMancer
    @Amigaz
    Perhaps. Although simple MorphOS tools should behave the same in all hardware configurations, due to the HAL *me shrugs*
    [ Edited by AmigaMancer on 2006/12/20 16:23 ]
    Amiga 1200 user.
  • »20.12.06 - 12:22
    Amigaz
    AmigaMancer wrote:
    @Amigaz
    Indeed  ;-)
    Pegasos II G4 1ghz
    Radeon 8500 128mb
  • »20.12.06 - 12:37
  • rms
    rms
    Posts: 606 from 2004/11/27
    Hi all,
    Yes I have (or should I say had) the same problem but here it happend only with YAM (have a look at the YAM 2.5 beta MOS treat on MorphZone) after a reset of the Peg2.
    This also startet to happen after the MUI4 installation as I do not have that one my other Pegs with MUI 3.9.
    Yesterday I stopped the Peg during OF startup and entered "printenv" to see if something could be wrong in there, but nothing was (I think). After that I reset the Peg and now the problem is gone!!!!!! Why???????
    And here also Transstats doesnt work anymore.
    Regards
    Christoph
  • »21.12.06 - 05:05
  • rms
    rms
    Hi all,
    I found 2 more strange things after MUI4 installation:
    1) when clicking in NListree to open the "closed node" image it opens the choose color requester instead.
    2) in IBrowse the edit text windows in html pages are completely black if unselected. I was not able to find a solution to change this in MUI settings.
    For better understanding, I enclosed to jpg's.
    Regards
    Christoph
  • »21.12.06 - 11:46
    tokai
    Posts: 1289 from 2003/2/25
    The trancestat problem is a MUI4 bug. So if you don't use MUI4 you will not notice this problem. Nothing related to HAL or whatever ;)
    ABout the black problem. Try to delete MUI prefs and see if this changes things. AFAIR it was related to what kind of colours you choosed (normal RGB colour, pen or pattern). I don't have the problem here with MUI4, so its possible to solve ;) I only do not remember how exactly. :P
    Besides that MUI4 is know for its buggyness.. thats the deal of alpha/beta testing experimental stuff ;)
    regards,
    tokai
  • »21.12.06 - 11:52
    catohagen
    Posts: 297 from 2003/5/20
    i managed to nail this fucker after editing every configurable colorsetting in mui, and found its in the string config, below string fonts
    there are 3 containers, you have to edit these (container/activated/readonly) even if they look grey or whatever before.
  • »26.12.06 - 18:40
    catohagen
  • »26.12.06 - 18:41
  • rms
    rms
    This is great, thanks for having submitted this info.
    Regards
    Christoph
  • »27.12.06 - 04:17
