Fedora Core 6 booting
    diezi7
    Posts: 167 from 2005/7/26
    I downloaded and installed FC6
    When booting from OpenFirmware I get an error:
    /boot/vmlinuz-2.6.18-1.2978.FC6 is not a valid ELF image
    Maybe the file is corrupted? Thew partition has ext3 format.
    I would appreciate any help...;-D
    Pegasos II G4 (not working)
    Powerbook G4 1.0 15"
  • »12.12.06 - 08:53
    GK_LKA
    Posts: 481 from 2004/3/28
    Try this:
    hd:3 boot/yaboot/yaboot conf=hd:3,/boot/yaboot/yaboot.conf
    (Of course replace hd:3 with your own linux partition.)
    [ GK / LKA Team ]
  • »12.12.06 - 08:55
    diezi7
    I use the same but with hd:1, linux partition.
    I don?t know why, but it doesn?t boot
  • »12.12.06 - 09:22
    neongod
    Posts: 34 from 2006/6/14
    I installed fedora core 6 from the DVD.
    I use this boot command:
    boot /pci/ide/disk@1,0:0 yaboot/yaboot conf=/pci/ide/disk@1,0:0,yaboot/yaboot.conf
    (the "boot/yaboot/yaboot" path is not working here)
    It brings up the yaboot boot prompt, where after a few seconds or if pressing the enter key, yaboot loads the default kernel without any problem.
  • »12.12.06 - 10:03
    Genesi
    Posts: 239 from 2005/1/7
    David Woodhouse of RedHat just received his EFIKA yesterday. He will port FC6 to the EFIKA. We will cover that at www.powerdeveloper.org not here. Interestingly, David also manages the OLPC image...;-)
    The MorphOS-Team has begun to receive their EFIKAs as have many MorphOS application developers. We are still hoping for MorphOS to be a big success and we don't see any reason why it will not be.
    R&B :-)
  • »12.12.06 - 12:05
    diezi7
    Hi :)
    In my setup yaboot (dir) resides in boot (dir) too.
    I write this at OF, but fails when loading image:
    boot hd:1 /boot/yaboot/yaboot conf=hd:1,/boot/yaboot/yaboot.conf
    But there?s an error with the elf image so I suppose
    I need to reinstall and repartition the HD.
    I can?t manage to make it work. Didn?t have such problem with YDL4.0 nor FC4.
    Thanks..
  • »13.12.06 - 09:46
