amiatlas6.38 morphos
    amiga4001
    Posts: 454 from 2006/11/16
    I tried to install this great program.
    But no nothing snoopdos says is looking for picasso96 files(libs).
    After copying these files still nothing.
    Can it be made to work?
    Or only under E-UAE?
  • »11.12.06 - 19:08
  • mk
    mk
    Posts: 72 from 2004/5/24
    No Picasso libs necessary.
    AmiAtlas6.38 (only AOS/68k nativ available) work at Peg2/G4 with MorphOS (also with new Ambient/MUI4).
    [ Edited by mk on 2006/12/12 6:13 ]
  • »12.12.06 - 03:11
    amiga4001
    Maybe not running bacause I've still go os 1.4.3??
    Well have to wait for updates I guess.
  • »12.12.06 - 04:18
    Posts: 1084 from 2003/3/24
    Then you should update to MOS 1.4.5!
  • »12.12.06 - 07:10
    DoctorMorbius_FP
    Posts: 315 from 2004/2/13
    Then you should update further!
    MorphOS 1.4.5+
    [ Edited by DoctorMorbius_FP on 2006/12/12 21:09 ]
  • »12.12.06 - 17:33
    amiga4001
    Have no acces yet not yet registered on the server.
    Will have to wait till januari before regs are being taken.
    Too bad but I already updated the ambient with a newer version which
    already has more features.
    Stil windows off drives/directory's can't be snapshot on size or
    position icon's.
    And can't find a way for shortcut for cleaning up icons like on
    os3.0(aamiga .)
    Or is there a way program to do this?
    And is it possibble to use the automatic recognisation of filetypes?
    Like .lha .mpeg for starting automatically a dearchiver(voodoo-x) or
    Mplayer for mpg/avi etc..
    This was called def icons on os3.9??
    Well I gotta say I should have upgraded earlier to the pegasos!
  • »12.12.06 - 20:07
