def icons
    koan
    Posts: 303 from 2005/11/21
    Hi
    I'm trying to sort out some of these small problems I
    still have with my MorphOS installation.
    def icons don't work for me!!
    I specify my def icons directory to be on disk
    in Ambient Settings, it picks up on the def_drawer
    and def_disk but nothing else.
    Have I missed a setting somewhere ? I still have the
    old fashioned saw def_tool but I don't know where that
    icon is stored - it is not in envarc:
    Am I correct in thinking def icons are identified by
    extension ? filetypes work for me.
    I'm using CVS build from 03.08.2006
    thanks!
    koan
  • »06.08.06 - 09:46
  • Fab
    Fab
    Posts: 1331 from 2003/6/16
    Deficons have changed quite a lot. Now they're linked to filetypes. However def_disk, def_<devicename>disk, def_drawer and def_tool are still there for now.
    So, assuming you have a correct ambient setup (i.e with recognition.db and working filetypes), it works like this :
    let's say you have an audio/mp3 type field for your mp3 filetype (it's provided in recognition.db), then ambient will try to use <deficon path>/audio/mp3.info. If it's not found, then it will fallback to <deficon path>/audio/default.info, and if not found it will end to internal/default.info or so.
    Check snoopium output and you'll understand better. :)
    Anyway, you can use bladerunner's very useful deficon archive. It's already synchronized to recognition.db and icons are named and sorted properly.
    This link may change, but take it while it's here : http://www.oli-hummel.de/temp/def-icons.lha
  • »06.08.06 - 11:32
    koan
    Hi Fab,
    Thanks for the help. With that archive I now have nice def icons :-)
    I'm now looking for an option to stop Ambient making them look dark.
    I think def_tool must be hard coded ? Unless it should live as
    application/tool.info ?
    koan
  • »07.08.06 - 06:16
    koan
    Thanks Luky.
    When I used Ambient CVS install script my old Advanced.conf,default did not get overwritten. That's why I didn't spot this option.
    I had to restart to make this work, don't know why.
    koan
  • »08.08.06 - 06:05
    magnetic
    Posts: 2129 from 2003/3/1
    Fab
    Hi.
    I downloaded the def icon pack. WHere do I install it please?
    tia
    magnetic
  • »10.08.06 - 05:32
    Amigaz
    Posts: 121 from 2005/6/11
    Can this def ifon package still be downloaded?
    MorphOS PowerUP powered Amiga 4000
    Pegasos II G4 1ghz
    Radeon 8500 128mb
    Soundblaster Live 5.1 Digital
    Realtek 2139B 100mbit
  • »03.12.06 - 06:49
    Amigaz
    ^BUMP^
    Pegasos II G4 1ghz
    Radeon 8500 128mb
  • »03.12.06 - 19:30
    Bladerunner
    Posts: 418 from 2004/2/19
    Well, after having most of the Work lost due some HD Problems (Yeah I hear you saying "backup" well, I made one, however most work was done in that month I didn't have a backup) I wasn't that sure to make them again.
    However I *am* currently working on a new set, but progress is slow, sorry.
  • »03.12.06 - 20:01
    Korni
    Posts: 473 from 2006/2/23
    Yes, it can :P
  • »03.12.06 - 20:17
    Posts: 423 from 2005/4/9
    "Yes, it can :P"
    where?
    zx.spectrum@3.5
  • »03.12.06 - 22:08
    Posts: 1932 from 2003/10/19
    I have them all still in my system. I can upload them to a server if anyone wants them still.
  • »03.12.06 - 23:15
    hooligan
    Posts: 1948 from 2003/2/23
    http://koti.phnet.fi/yh14756/def-icons.lha
    Grab it while you can.
    It was fun while it lasted
    [ Edited by hooligan on 2006/12/4 16:03 ]
  • »04.12.06 - 02:27
    Amigaz
    Thank ya!
    Will grab em' when I get home from work
    Oh...and I just put them into sys:prefs/env-archive/sys?
    Pegasos II G4 1ghz
    Radeon 8500 128mb
  • »04.12.06 - 07:19
    Bladerunner
    Oh cool... so you don't think there was a reason why *I* took them off from my HP, right?
    Well, nevermind. Then keep the uncomplete Test Release, in exchange I will keep the full set.
  • »04.12.06 - 07:23
    Wishmaster
    Posts: 342 from 2003/6/29
    You put them where your Ambient Icons are.
    (Ambient/miscellaneous/path to default icons)
    Pegasos PPC
  • »04.12.06 - 10:01
    hooligan: thx a lot man!
    bladerunner: sorry:)) i jus wanna test it. dont get mad !:)
    zx.spectrum@3.5
  • »04.12.06 - 11:41
    hooligan
    Chill :-)
    I will take the file off page. Dont understand why you get so upset about it.. its a very useful set as it is.
  • »04.12.06 - 12:00
