Aweb won't start.
    amiga4001
    Posts: 454 from 2006/11/16
    Just downloaded Aweb(morphos) and classact from aminet(classactdemo).
    Aweb won't start no gui nothing.
    Strange thing is it worked a couple off weeks.
    But messed around in boot partition too much I think.
    Snoopdos don't help all is well..
    What is it missing??
  • »03.12.06 - 08:37
    Posts: 1521 from 2003/2/24
    Something is missing and very likely it is some font missing. Try again with SnoopDos and make sure OpenFont function is enabled in SnoopDos.
  • »03.12.06 - 09:12
    Framiga
    Posts: 363 from 2003/7/11
    @amiga4001
    i got exactly the same problem with AWeb at the beginning of my MOS experiences(?).
    It was due a CA classes/gadgets mixed with my Reaction (from OS3.9) installation.
    Check again your SYS:Classes/ .class and .gadget
    (in MOSSYS:Classes/Gadgets/ you "should" have only the colourweel and gradientslider.gadget as default)
    Edit- ah... and remove any old Aweb assign, if you have any. Isn't necessary anymore
    [ Edited by Framiga on 2006/12/3 13:51 ]
  • »03.12.06 - 10:46
    amiga4001
    Reinstalled morphos on the boot partition.
    Reinstalled Aweb latest version(3.5.08) and reinstalled classact.
    Now it works!
    Strange maybe I did manage to also install reaction somehow?
    Well working now?so happy.
  • »03.12.06 - 16:38
    Brumiga
    Posts: 276 from 2004/4/3
    @amiga4001,
    AWeb needs the bitmap fonts courier and times. In the archives are only provided the big sizes 24 and 36.You need the original ones from wb 3.x on floppy or cd to get them, then use fixfont tool to fix the .font files for all sizes they allow.
    Brumiga
  • »03.12.06 - 18:10
    DoctorMorbius_FP
    Posts: 315 from 2004/2/13
    @ amiga4001
    ...and if you want much more, read this tutorial: here or here.
  • »03.12.06 - 19:37
