Posts: 121 from 2005/6/11
tokai wrote:
dunno about the AHI version, maybe a newer one was released after the mos1.4.5 release. Just download the latest ahiusr archive for MorphOS from aminet and compare the versions strings to find out:
> version full file mossys:devs/ahi.device
etc.
About the audio cds. CDrive (the cdrom filesystem) from MOS 1.4.5 doesn't support audio cds. But that doesn't mean you can't use audio cds ;) I suggest you have a look at itixs CD Player (lehtoranta.net) or at optycdplayer (aminet). BUt also should work just out of the box with Kaya or Songplayer. You just need to configure for all these programs the correct device/ unit.
e.g. you have the CDROM connected to the 2nd ide port on your peg as master, then you would use ide.device unit 2. If you're not sure about the unit you can use SYS:tools/unitcontrol to find it out (it lists all connected ide/scsi hardware with proper device and unit).
Hope that helps.
regards,
tokai
Just installed latest AHI, the file sizes differed so it must have been another version :D
Using MOS PowerUP here and all devices are connected to my UWSCSI on my Cyberstorm PPC
I'll give those cd players a go ;)
Songplayer was set to use cybppc.device, unit 4 which is the ID of my cd-rom
MorphOS PowerUP powered Amiga 4000
Pegasos II G4 1ghz
Radeon 8500 128mb
Soundblaster Live 5.1 Digital
Realtek 2139B 100mbit
