SimpleMail NListview columns
    r-tea
    Posts: 315 from 2005/3/27
    Hi!
    Do You got the same what me?
    Since I switched to a new MUI alpha/beta, NListview separators of columns in my SimpleMail, get as close as it's possible each other after every start of Simplemail.
    And one more thing, SimpleMail doesn't display the list of Incoming folder content on startup. To view its content I have to click on another folder first, and then click back to the incoming. After that the listview fills with e-mails. Besides this I have to resize columns to the proper widths, of course.
    It's annoying.
    Waiting fo your advices how to manage this :)
  • »08.06.06 - 19:54
    beanbandit
    Posts: 50 from 2006/4/19
    yes, exactly the same problem :-)
  • »08.06.06 - 23:23
    magnetic
    Posts: 2129 from 2003/3/1
    I have had this problem for ages as well. Rather annoying I must say...  :-?
    Maybe Henes will see this and have an answer.. AFAIk he is the MOS maintainer..
    magnetic
  • »09.06.06 - 15:07
    Henes
    Posts: 507 from 2003/6/14
    The empty folder content problem is already solved for the next release.
    About the small column bug... I do not know. It works fine for me.
    But I remember I once experienced such problem and I think it was caused by some buggy nlist classe. Not sure.
    If you start updating your MorphOS system using alphabetagamma libraries... you must accept to suffer a bit :-)
  • »09.06.06 - 15:53
    beanbandit
    the fault with the small nlist columns is that one probably
    have a incorrect version of the nfloattext.mcc, download the
    nlist package from sourceforge.net
    (http://www.sourceforge.net/projects/nlistclasses, IIRC)
    and copy over the nfloattext.mcc over the one that is currently
    installed... it fixed it for me at least :-)
    [edit]
    the 'buggy' version was for 19.51...
    the correct one is 19.52
    [/edit]
    [ Edited by beanbandit on 2006/6/9 21:35 ]
  • »09.06.06 - 18:34
    magnetic
    bean and henes
    thx
    will try this
    magnetic
  • »09.06.06 - 22:51
    r-tea
    @ beanbandit
    the fault with the small nlist columns is that one probably have a incorrect version of the nfloattext.mcc
    [edit]
    [/edit]
    Unforyunately I already have 19.52 (31.07.2005). :-(
    YAM uses nlistviews too. Why there is no such problem?
    BTW, downloading it from Aminet is easier and faster than from sourceforge. Much less clicks. :-)
  • »10.06.06 - 08:15
    r-tea
    @ Henes
    When I started this topic, I used SimpleMail 0.27.
    Just downloaded 0.29 and the empty folder bug still exists here.
  • »25.11.06 - 19:39
    r-tea
    @ beanbandit
    The problem still occours here.
    I use SimpleMail 0.29, Ambient 1.43 (14.9.2006) [debug], MUI4 alpha, v20.6373 05.06.06 debug version.
    My nlist classes are:
    NFloattext.mcc 19.52
    NList.mcc 20.116
    Nlistview.mccc 19.71
    NListviews.mcp 19.67
    All from 31.07.2005
    And what are your MOS components?
  • »25.11.06 - 19:51
    Henes
    Sure. There was no SimpleMail update after the creation of this topic :-)
  • »26.11.06 - 09:24
