Installation problems...
    ravnen
    Posts: 9 from 2006/11/13
    I have a Peagsos II card MorphOS 1.4.5 on cd.
    I follow the installation as described here: http://www.morphos-news.de/beta2help/qstart_en.html
    Everything looks good, until i try to boot from the harddrive.
    The MorphOS logo is displayed, but then nothing happens.
    There is only an agp card installed.
    any hints?
  • »21.11.06 - 18:58
    merko
    Posts: 328 from 2003/5/19
    Find a text editor somewhere and put "wait 1" before the line where IPrefs is started. This seems to be a quite common cause to this exact problem.
  • »21.11.06 - 20:05
    ravnen
    Thanks!
    I'll try this when i come home. There is no usb devices connected (I disconnected everything except ps2 keyboard and mouse).
    [ Edited by ravnen on 2006/11/22 9:08 ]
  • »22.11.06 - 05:57
    ravnen
    hmmm, how do I do this without an text editor. Is there one on the boot cd?
    [ Edited by ravnen on 2006/11/22 15:11 ]
  • »22.11.06 - 11:55
    merko
    No, for some reason they forgot to put one there. Yes, this can be a real pain.. :)
  • »22.11.06 - 12:30
    ravnen
    okay. So how do I do this?
    I attached a usb harddrive, I see it in the morph config under usb, and the debug tells me it is avaiable under usbscsi, but can I access this someway?
    Or what about going the network way, there is no included tcpip stack as I remember, so how am I supposed to get an editor over ???
  • »22.11.06 - 12:33
    amiades
    Posts: 231 from 2005/6/2
    You can get the editor and some more things you may need into a cdrw until you get you peg started propperly.
  • »22.11.06 - 13:16
    ravnen
    installing morph is a pain!!!
    Okay, I found an editor on aminet, burned it over to a cd...
    But morphos is not to happy with me ejecting the morphos cd, and why would it? The system just locks up.
    I tried to open a cli window, before ejecting it, and I got to access the burned cd but I dont have any commands to work with, since the morphos cd is ejected. I even tried to assign Morphosboot: to system: but no luck, what kind of stupid operating system is this anyway?
    Any help would be apriciated.
  • »23.11.06 - 14:21
    hooligan
    Posts: 1948 from 2003/2/23
    A new MOS-image should be created with Jaceks Ed included.
    My two cents ;-)
  • »23.11.06 - 14:26
    ravnen
    okay, I found that if I start terminal from system: and use system:morphos/c/copy to copy and switch back to the morphos cd afterwards it works.
    But just to find out that the editor did not work.
    Can anyone give me a link to a simple text editor, pre compiled.
    [ Edited by ravnen on 2006/11/23 17:36 ]
  • »23.11.06 - 14:34
    roschmyr
    Posts: 210 from 2003/2/20
    @ravnen
    http://henes.free.fr/software/janoeditor/JanoEditor.lha
  • »23.11.06 - 14:43
    ravnen
    @roschmyr
    Thanks, it works!
    Finaly. Somebody needs to do something about this cd image!
  • »23.11.06 - 14:56
