MOSNet/ifconfig: changing MTU settings?
    Posts: 109 from 2006/9/10
    Is there any way to change MTU settings for an
    interface when using MOSNet/ifconfig? When trying this with ifconfig I just get the
    following error message:
    ifconfig eth0 mtu 1496
    ifconfig: SIOCSIFMTU: Operation not supported
    Thanks in advance for any suggestions.
  • »09.11.06 - 19:11
    CISC
    Posts: 619 from 2005/8/27
    I don't know about MOSNet, but in AmiTCP you can set MTU in db/interfaces, like this:
    via0 DEVICE=MOSSYS:Devs/Networks/via_rhinepci.device UNIT=0 MTU=1500
    - CISC
  • »09.11.06 - 19:37
    Thanks, but unfortunately this doesn't work - the MTU-variable doesn't seem to be recognized by MOSNet. When starting up the TCP/IP stack I just get an error message pointing to the "MTU=1496" entry in db/interfaces.
  • »10.11.06 - 07:21
