Zipdrive with MOS
    Coder
    Posts: 296 from 2003/3/5
    I got a spare Iomega zipdrive that I want to use with my Pegasos/Morphos setup. Anyone tried it before? If so, let me in on the secret. :-)
    Coder
  • »18.08.03 - 11:11
    cd32
    Posts: 18 from 2003/8/16
    check there
    http://www.e3b.de/usb/main_supported_e.html
  • »18.08.03 - 11:28
    cd32
    i don't think it will work
  • »18.08.03 - 12:49
  • Targhan
    Posts: 2833 from 2003/2/8
    I have an USB Zip100, that works fine :)
    :idea:Targhan
  • »18.08.03 - 17:23
  • Targhan
    IIRC, those drivers required the game-port, the parallel port, and a hack-cable to connect to the zip drive. Please see Iomega's Amiga Pages.
    There could have been something since those pages were made for Amiga's with I/O adapters. If there were, then those drivers would likely work. (I.E., a Parallel-Zip drive to something like a Hypercom+ card).
    :idea:Targhan
  • »18.08.03 - 18:25
    serge
    Posts: 725 from 2003/2/20
    USB version works fine here. Parallel dont know. Maybe adapting the special amiga installation.
  • »19.08.03 - 07:00
    Tomo
    Posts: 92 from 2003/7/29
    I have an internal zipdrive in my Pegasos.
    It works fine. Place in L: the fastfilesystem and use Iotools (WB 3.9)
    Succes
  • »19.08.03 - 11:16
