New Python-Blender releases
    Yomgui
    Posts: 348 from 2004/8/31
    New release of Python to fix some issues w/ Blender.
    ... and first public release of Blender 2.42a, the one with Nodes!
    Note: Game engine is disabled, come back soon.
    Download Python:
    http://www.yomgui.fr/python/arc/python-2.4.2-mos_6b-final-20061016.lha
    Download Blender:
    http://www.yomgui.fr/blender/arc/blender_2.42a-mos_bin-20061016.lha
    And now... next project!
  • »17.10.06 - 05:57
  • MDW
    MDW
    Posts: 484 from 2003/7/25
    It is great news! Thank you!
    However new Blender doesn't work because I don't have jfif.library. I can't find this library. Heeeeeelp me, please...
  • »17.10.06 - 06:17
    MarK
    Posts: 641 from 2004/1/25
    afaik, isn't the jfif.library a part of MorphOS 1.5? i suppose, i have read this somewhere already...
    bye, MarK.
  • »17.10.06 - 06:21
    Yomgui
    jfif.library? hmmm normally I've compiled with static libraries, not dynamic ones.
    I will check that...
  • »17.10.06 - 06:26
  • MDW
    MDW
    MarK:
    You're right probably. Bledner 2.42a only for MorphOS 1.5 - it is terrible. :( I'm crying...
    Yomgui:
    Is ifif.library absolutely necessary for Bledner 2.42a? Users MOS 1.4.5 don't have this library. We are sad... :(
  • »17.10.06 - 06:29
  • MDW
    MDW
    Snoopium log:
    [1] [Blender] [ChangeDir] [Progs:Graphics/Blender] [] []
    [2] [ramlib] [Load] [MOSSYS:LIBS/jfif.library.elf] [] [Fail]
    [3] [ramlib] [Open] [MOSSYS:LIBS/jfif.library.elf] [Read] [Fail]
    [4] [ramlib] [Open] [MOSSYS:LIBS/jfif.library.elf] [Read] [Fail]
    [5] [ramlib] [Load] [MOSSYS:LIBS/jfif.library] [] [Fail]
    [6] [ramlib] [Open] [MOSSYS:LIBS/jfif.library] [Read] [Fail]
    [7] [ramlib] [Open] [MOSSYS:LIBS/jfif.library] [Read] [Fail]
    [8] [ramlib] [Load] [LIBS:jfif.library.elf] [] [Fail]
    [9] [ramlib] [Open] [LIBS:jfif.library.elf] [Read] [Fail]
    [10] [ramlib] [Open] [LIBS:jfif.library.elf] [Read] [Fail]
    [11] [ramlib] [Load] [jfif.library.elf] [] [Fail]
    [12] [ramlib] [Open] [jfif.library.elf] [Read] [Fail]
    [13] [ramlib] [Open] [jfif.library.elf] [Read] [Fail]
    [14] [ramlib] [Load] [LIBS:jfif.library] [] [Fail]
    [15] [ramlib] [Open] [LIBS:jfif.library] [Read] [Fail]
    [16] [ramlib] [Open] [LIBS:jfif.library] [Read] [Fail]
    [17] [ramlib] [Load] [jfif.library] [] [Fail]
    [18] [ramlib] [Open] [jfif.library] [Read] [Fail]
    [19] [ramlib] [Open] [jfif.library] [Read] [Fail]
    [20] [ramlib] [Load] [PROGDIR:LIBS/jfif.library.elf] [] [Fail]
    [21] [ramlib] [Open] [PROGDIR:LIBS/jfif.library.elf] [Read] [Fail]
    [22] [ramlib] [Open] [PROGDIR:LIBS/jfif.library.elf] [Read] [Fail]
    [23] [ramlib] [Load] [PROGDIR:LIBS/jfif.library] [] [Fail]
    [24] [ramlib] [Open] [PROGDIR:LIBS/jfif.library] [Read] [Fail]
    [25] [ramlib] [Open] [PROGDIR:LIBS/jfif.library] [Read] [Fail]
  • »17.10.06 - 06:31
    Yomgui
    ... or just dump the .rodata section of blender, there is the list of needed libraries :-(
  • »17.10.06 - 06:44
    Frostwork
    Posts: 302 from 2003/4/18
    Cool work , Yomgui! (though I don't have mos1.5...)
    Pygame would be really cool for mos, too ;)
    & maybe (if possible) a standalone "blender-game-player" ...
    cheers
    frostwork
  • »17.10.06 - 06:58
    Jupp3
    Posts: 1193 from 2003/2/24
    Hope we will get Blender "Mortal Edition" soon :-)
  • »17.10.06 - 12:58
    Yomgui
    I've just uploaded a new build (same filename).
    Normally libraries jfif/png/.. are not needed now.
    But I've just seen that a crash may happen when you leave Blender.
    If you've the same issue, please report me that.
    Thanks,
    Guillaume
  • »18.10.06 - 06:16
  • MDW
    MDW
    I downloaded, and tried this version. Now everything is ok.
    Blender 2.42a works on MorphOS 1.4.5... It is amazing. :) Thank you! You are the best!
  • »18.10.06 - 07:20
    beanbandit
    Posts: 50 from 2006/4/19
    no crash here... but I just did a quick start, fiddle, stop
    thing.
    what are the chances of seeing the Verse version of blender?
    (is the Verse version still being developed?)
  • »18.10.06 - 15:45
  • MDW
    MDW
    I have the problem in Blender 2.42a. Sometimes I see black rectangle in 3D window. For example if I load "dolphin.blend" (from test237) archive), this rectangle will be visible. I noticed that if I turn off option "Mini Axis" ("View & Controls"), black rectangle will disappear. Black rectangle is visible only if I set view from camera (key '0' on numeric keyboard). In Blender 2.41 for MorphOS I didn't see this rectangle...
    I like mini axis and I want it. :) Help me, please...
    Screenshots:
    1. Mini Axis On:
    http://encoreppc.republika.pl/blender/pic_000.png
    2. Mini Axis Off:
    http://encoreppc.republika.pl/blender/pic_001.png
    Example:
    http://encoreppc.republika.pl/blender/dolphin.lha
    Sorry for my English. I can't write better now. I still learn this language. :)
  • »18.10.06 - 18:15
    Yomgui
    Known bug, as written in MorphOS_changes.txt ;-)
    Another workaround is to show the camera name:
    Select the camera object (in 3D view for example), press F9 (many times possible) to have the camera properties, then in "Show:" enable "Name" button.
    Normally, the code use a glRectf() function to draw a black rectangle but only the frame.... here the rect is filled.
    But not always (if the workarounds are done).
    Very strange. I think that Kiero is the man to solve this issue.
    Kiero, if you read us...
  • »19.10.06 - 05:55
  • MDW
    MDW
    "Another workaround is to show the camera name: Select the camera object (in 3D view for example), press F9 (many times possible) to have the camera properties, then in "Show:" enable "Name" button."
    It really works! Black rectangle disappeared and I see Mini Axis. Thanks for temporary solution. :)
    "Normally, the code use a glRectf() function to draw a black rectangle but only the frame.... here the rect is filled. But not always (if the workarounds are done)."
    It is strange... If you knew in which place of the source is drawn this ractangle, you would replace glRect to 4 x glLine (GL_LINE). :) Only temporarily and only in version for MorphOS. I know - it isn't pretty way. But maybe... What do you think? :) Is it possible?
    [ Edited by MDW on 2006/10/19 12:54 ]
  • »19.10.06 - 09:53
    Yomgui
    Or a better one: using an array of 4 gVertex ;-)
  • »19.10.06 - 11:11
  • MDW
    MDW
    "Or a better one: using an array of 4 gVertex"
    You're right. :) 4 glVertex and GL_LINE_STRIP is better way. :)
  • »19.10.06 - 11:24
    kiero
    Posts: 129 from 2003/2/28
    LINE_LOOP:)
  • »19.10.06 - 11:30
    Yomgui
    Kiero: it was not really the answer that I wait for....
    About the bug now? Do you think that something is wrong with glRect on TGL?
  • »19.10.06 - 11:40
    kiero
    yomgui: that was a reply for GL_LINE_STRIP post (which wouldn't close the loop). need to get home to check what might be wrong with the code.
    and about the glRect. no, there is nothing wrong with it. it's just simple wrapper for 4 other calls. what might be wrong is shape outline drawing, but that worked iirc. can't tell more now.
    [ Edited by kiero on 2006/10/19 13:50 ]
    [ Edited by kiero on 2006/10/19 13:51 ]
  • »19.10.06 - 11:50
