RDesktop with 24 bits
    Posts: 66 from 2003/10/5
    Almost giving up... I cannot manage to have RDestkop
    working with 24 bits. I'm connecting to a remote XP computer on my LAN, everything's fine but if I specify
    DEPTH=24 then I get a requester saying "Server limited max depth to 16 bits". That either using a desktop window or a custom screen. Why ? Perhaps I have to tweak with some obscure XP setting ?
    Any suggestion is welcome...
  • »13.10.06 - 17:08
    BIG THANKS !!!! It works now :-)
    I think that should be mentioned in RDesktop readme
    somewhere ;)
  • »13.10.06 - 19:50
    Posts: 236 from 2003/7/28
    I have added it to the FAQ's on the Remote Desktop web page at http://www.hd-zone.com
    I will also put it in the readme for the next release. By the way, working on Windows VISTA support now... :)
  • »14.10.06 - 13:49
