AmRSS with MUI4
    GK_LKA
    Posts: 481 from 2004/3/28
    Ave!
    HTMLview MUI class has been stopped working since I installed MUI4, so I can't use amrss anymore. (The HTML view looks ugly blue...)
    Here are some screenshots
    There is a MUI4 special edition of this program on alfie's home page, so I think it shall work, only I have some troubles - but what's wrong?
    Both MUI4, amrss and htmlview classes are the latest versions (I think...).
    [ GK / LKA Team ]
  • »23.09.06 - 10:00
    Posts: 1520 from 2003/2/24
    I suspect HTMLview is using old double buffering trick no longer valid
    in MUI4.
  • »23.09.06 - 12:56
    GK_LKA
    Hm, and there is no solution? Then why is this "MUI4 special version"?
    [ GK / LKA Team ]
  • »23.09.06 - 19:12
    I cant be sure is it this double buffering but looks like it and this
    has changed in MUI4 a bit... There is no way to work around this
    unless someone fixes HTMLview.mcc...
  • »23.09.06 - 20:08
  • tom
    tom
    Posts: 149 from 2003/7/22
    I hope it will be fixed soon. I used the programma quite often......
    Now its useless.
    regards, Tom
  • »24.09.06 - 17:31
    koan
    Posts: 303 from 2005/11/21
    @GK_LHA
    I am using amrss with MUI4 alpha.
    I vaguely recall I needed to reinstall HTMLview class at one stage.
    Sorry I can't be more help but I can only reassure you that if you find the right combination it will work.
    cheers
    koan
  • »25.09.06 - 05:27
    Otti
    Posts: 20 from 2004/3/31
    Same here.. it didn't work.
    Display is flickering an output is broken.
    AmRSS was a nice programm, I would like to use it further....
    Found on the Authors Page that the code was recovered and now Jens Langer could
    change it.
    Watch this Link:
    http://www.diku.dk/hjemmesider/studerende/duff/index.html
    I hope the Class will be fixed soon...
  • »25.09.06 - 10:53
