Quake problems
    motorollin
    Posts: 74 from 2006/8/30
    I'm trying to get Quake to run on my PegII. I've got the id1 folder from the PC version.
    I've tried GLQuake, but the launchers give me an error that I need a host name. I ran the executable from the shell with the command line option "ip=127.0.0.1" and it opened the screen, but then quit with some memory allocation error (even though I've got loads available).
    I then tried QuakeMOS which loads, but the graphics in any screenmode higher than 640x480 are fked: everything is squashed up one side of the screen and black and white. The same screenmode in Ambient displays fine.
    Hopefully someone can help me to get one of these version of Quake running. Also, is there a Quake II binary for MorphOS?
    Thanks
    moto
  • »07.09.06 - 09:21
    Jupp3
    Posts: 1193 from 2003/2/24
    It doesn't work if you don't get a valid hostname from TCP/IP (or somehow specify one yourself)
    Try if it works when you have no TCP/IP running. That way it should DEFINITELY work...
  • »07.09.06 - 11:31
    CLS2086
    Posts: 168 from 2005/8/25
    Use Bigfoot FuhQuake instead of ...
    http://bigfoot.morphos-team.net/files/
    [ Edited by CLS2086 on 2006/9/7 13:01 ]
    Keep the Faith !
    VG 5000/A1000/500/500+/600/2000/1200PPC-GREX/1200PPC-ATEO/1200+1230-IVFPUSCSI/CD32/Pegasos 1 April1 G3/Pegasos 2 G4/ Ahtlon/K6-3/various funny machines too :-)
  • »07.09.06 - 12:01
    Toto
    Posts: 268 from 2003/4/20
    You can find Quake II here.
  • »07.09.06 - 12:27
    bigfoot
    Posts: 510 from 2003/4/11
    Fuhquake is indeed the way to go unless you really require Netquake(original variant of Quake) support.
    If you want to play online and don't know the difference, what you want is Quakeworld, which is what Fuhquake is. If you want to play regular Quake single player, Fuhquake is also good. What Fuhquake can't do is play on Netquake servers (of which there aren't many anyway) and it can't use old regular Quake mods.
  • »07.09.06 - 15:32
    motorollin
    Thanks guys - got FuhQuake working. It runs really well! I'll try Quake II later :-)
    moto
  • »07.09.06 - 16:31
