sync tool for directories ?
    judas
    Posts: 175 from 2005/1/14
    I'm looking for a tool which can easily sync two dirs.
    On linux, there's dirdiff (tcl/tk based), on windows, there's
    totalcommander... is there anything similar working under MorphOS ?
  • »04.09.06 - 11:08
    hooligan
    Posts: 1948 from 2003/2/23
    You mean comparing directories? Magellan has this.
  • »04.09.06 - 13:06
    saragaglia
    Posts: 12 from 2004/9/3
    Rival ?
    http://de4.aminet.net/util/dir/Rival-V1.0a-MOS.lha
  • »04.09.06 - 14:55
  • pOS
    pOS
    Posts: 220 from 2003/11/14
    FolderSync
  • »04.09.06 - 18:19
    judas
    * Foldersync worked "out of the box".
    * Rival required the use of snoopdos to locate the missing mui.classes.
    (thebar and betterstring..)
    .. but it looks much more friendly ..
    * Last not least, I own Opus Magelan II, but I didn't find
    a compare-function. Is this an internal command ?
  • »04.09.06 - 21:25
    judas
  • »04.09.06 - 21:25
    AKiLL
    Posts: 93 from 2006/3/6
    @judas
    I think Dopus Magellan II hasn't that kind of internal function. Anyway, folllowing our DoctorMorbiusFP precious help, I solved installing
    AleXCompare
    and then creating a toolbar button that provide fastly comparing files and whole dirs.
    The program compares files in two directories (or trees). That can be very useful, e.g. to examine in a backup, which files have been changed or rather are new. With cmp it is also possible, to compare two files and display the differences (hex-dump). With cmp and the device-handler (AmiNet:disk/misc/dev_hdl.lha) you can also compare disks/harddisks byte for byte.
    ByE
    __
    AKiLL
  • »04.09.06 - 22:38
    hooligan
    I think Dopus Magellan II hasn't that kind of internal function. Anyway, folllowing our DoctorMorbiusFP precious help, I solved installing AleXCompare
    Yep
  • »05.09.06 - 03:27
