Problems installing iBrowse
    motorollin
    Posts: 74 from 2006/8/30
    I'm trying to install iBrowse (latest demo) on MorphOS. When it gets to the part when it copies newstring.mcc, the install borks saying it can't find the file. I have downloaded newstring.mcc and copied it to SYS:Classes/MUI and pointed the installer to that location when it asks where MUI is installed, but it still can't find it.
    Is there a trick to getting it to work?
    moto
  • »01.09.06 - 18:27
    Bladerunner
    Posts: 418 from 2004/2/19
    There is (or should be?) a drawer in Sys:apps which is especially for MUI: (I thought there was even an assign pointing there) and legacy stuff where Installer can safely Install their classes and such. If there isn' t an assign you can temporarly make one (I assume I do not need to explain how to do so ;) ) and let IBrowse Install its Stuff there. Afterwards you can copy the needed classes to where you allready installed them, Sys:classes/Mui is the right place.
  • »01.09.06 - 20:00
    motorollin
    Hmmm, can't find anything in SYS:Apps. I tried to install Voyager and had a similar problem. I don't understand this - I have seen browsers running under MOS in screenshots :-?
    moto
  • »01.09.06 - 20:40
    Posts: 1520 from 2003/2/24
    As a last resort you could set MUI: assign to ram disk and let IBrowse installer use it... create some dummy directories and copy after installing IBrowse copy classes to their right place. I never installed IBrowse on Pegasos but copied old install from Amiga HD.
  • »01.09.06 - 21:14
    motorollin
    Well I found the solution :-) Here it is in case anyone else comes looking. I thought the error was that it couldn't find the file newstring.mcc. It suddenly occurred to me that maybe it can't find the drawer it wants to copy it to. So here's what I did:
    Add the following to S:user-startup
    Assign MUI: SYS:Classes/MUI
    Assign LIBS: MUI:LIBS ADD
    Then create the drawers SYS:Classes/MUI and SYS:Classes/MUI/LIBS. Then install iBrowse and it works :-D
    moto
  • »01.09.06 - 21:35
