MorphOS Developer
Posts: 619 from 2005/8/27
Even if a different license would be required (which I don't actually know, see above), how do we know Hyperion haven't got such a license? They have a good working relationship with the U-Boot team, AFAIK.
You should know, as Hyperion obviously make no secret of the fact that they use UBoot, you have a right to know which license they have been given the right to use it under, so that
you know which rights you have vis-a-vis the software in question.
If you _REALLY_ care, take it up with them.
I don't care, but it seemed like you did since you wanted to build your own, so I just told you how to get what you wanted .. but it seems I was wrong...
- CISC
