Fryingpan
    pegasosuser
    Posts: 138 from 2004/4/9
    I use Fryingpan to burn my cd's.
    now i can't not burn mp3 to the cd
    how to i that?
    we can help me
    greetings Cor van Londen.
    PEGASOSII G4@1Ghz Registered MorphOS2.5 & AmigaOS4.1 1024DDRam ATI RADEON9250-256Mb(128Bit) Creatieve Soundblaster Live! 2 x HD MAXTOR U-ATA133 160Gb 8Mb-Cache Plextor DVDR +- RW 708A 2Mb Buffer ONLY PEGASOS MAKE IT POSSIBLE!
  • »28.08.06 - 17:09
    Posts: 916 from 2004/1/24
    http://www.tbs-software.com/fp/welcome.phtml
    Guess all you need to know is explained there
    though it might help if you explain what your problem is ;-)
    [ Edited by Stevo on 2006/8/28 21:52 ]
  • »28.08.06 - 18:49
    r-tea
    Posts: 315 from 2005/3/27
    @ pegasosuser
    how to i that?
    It depends on what you want exactly to get.
    If you want to burn mp3 file as is, just add it in Disk Image Constructor tab, but if you want to burn it as raw audio you need to drop it into the Data/audio tracks tab.
    Note your mp3 should be layer3 44khz to FryingPan be able to convert it to a raw audio track.
  • »29.08.06 - 04:18
