                Posts: 363 from 2003/7/11
				try a
SFSCheck PartName: FRAGLIST
and then defragment all the SFS partitions.
If all the above fails, check/replace  the flat-cable along the HD
Edit- do you have this
SFSCheckMOS version?
[ Edited by Framiga on 2006/8/25 18:24 ]
