Posts: 568 from 2003/2/24
Just got Genesis working again, thanks to CISC!
Here's how I managed it:
If started Genesis creates the following dir -> ENV:NetConfig
In this dir there are 2 files:
- AutoInterfaces
- NoAutoTraffic
In AutoInterfaces I saw the following text:
ether0 DEV=Devs:Networks/via_rhinepci.device UNIT=0I completed this text with CISC's help sothat I got the following text:
ether0 DEV=Devs:Networks/via_rhinepci.device UNIT=0 MTU=1500 ADDR=00:04:12:03:21:10The
ADDR-part is the MAC-adress.
In GenesisPrefs you have to fill in the last part (from 'MTU...') in the window of your hardware-interface in the field
Params: (bottom-right)
Spidey
