ubuntu 6.06
    Tomo
    Posts: 94 from 2003/7/29
    This weekend i decided to try and get ubuntu running on my peg2.
    Ik downloaded the latest ubuntuPPC iso and burned it to a disc
    However, I don't seem to be able to boot it.
    Running in OF type into the terminal
    boot cd install/pegasos
    which takes me into a menu with 3 options.
    none of these work
    returning "install/vmlinuz not found"
    Had anybody been able to bootup the installer cd?
    Or am I missing something?
    regards, Tom
  • »18.08.06 - 15:58
    magnetic
    Posts: 2129 from 2003/3/1
    Tomo
    Yes, you need a boot image.. see here:
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=4696&forum=9
    for easiest way imo, if you have a MOS FFS boot partition.
    Or
    If you want to use a linux boot parition and GRUB check out:
    magnetic
  • »21.08.06 - 05:19
    SoundSquare
    Posts: 1214 from 2004/12/1
    and thr right forum for this kind of issues is here : www.ppczone.org
    ubuntu problems have been intensively discussed there.
  • »21.08.06 - 06:35
