Using an Audigy SE soundcard in the Peg with Morphos
    magnetic
    Posts: 2129 from 2003/3/1
    Hey guys
    Is it possible to use an Audigy SE soundcard in the Peg with Morphos and ahi?
    tia
    magnetic
  • »07.08.06 - 05:55
    imax
    Posts: 41 from 2004/9/20
    No. AHI v6 dont support sound chip CAO106 , see second hand EMU10K sound card (Audigy1 & Audigy2 will work).
  • »09.08.06 - 06:55
    magnetic
    imax
    Thanks alot. :( I was hoping it was supported as its the only Low Profile Audigy, and I have a half height case now..
    magnetic
  • »09.08.06 - 20:10
    imax
    1. Replace in new normal case (Inwin, GMC>=30, Foxconn)
    2. Kick Martin Bloom
    3. Buy the saw
  • »11.08.06 - 13:24
    magnetic
    imax
    1. I just took my peg out of a "normal" case to go half height and small form factor which is what peg is meant to be to me..
    2. well Martin does a great job for free so not much I can say ...
    3. I have a saw, but most audio cards are full height so a "saw" won't do much good.
    magnetic
  • »14.08.06 - 17:58
