MorphOS Developer
Posts: 619 from 2005/8/27
1) i'm using tun for network access, but have not figured out how to get TO osx from another host on my network. specifically, i'd like to remotely control (vnc) the osx desktop.
You have to forward some ports to MOL, with something like this in tunconfig (you probably need to modify this if not using MOLK and want to forward one range to another):
$IPTABLES -t nat -A PREROUTING -p tcp -i eth0 --dport <from>:<to> -j DNAT --to-destination 192.168.$NET_NUM.2
(put it last in the "$ACTION" = up block and set the appropriate <from>/<to> ports)
..and remember to open the OSX firewall as well...
is it possible to use hdd with MOLK?
Yes, ofcourse.
- CISC
