OpenSSH - PRNG is not seeded
    Yvan
    Posts: 79 from 2003/3/28
    I installed OpenSSH version 4.1p1 from
    http://home.elka.pw.edu.pl/~mszyprow/programy/openssh/
    I chosed the version working without GG.
    Now I just tried to open a session to my linux box by typing:
    ssh yg@hades
    and I always get the error message:
    PRNG is not seeded.
    What is wrong?
    By the way, I first sent this text to the mailing list morphos@ml.morphos-team.net
    but it didn't seem to arrive and I realised that I stopped getting mails from this mailing list.
  • »29.07.06 - 11:40
    GK_LKA
    Posts: 481 from 2004/3/28
    I think you should use
    ssh -l yg hades
    instead.
    [ GK / LKA Team ]
  • »29.07.06 - 11:51
    Yvan
    Both way should work,but anyway, ssh -l yg hades gives the same result.
    PRNG is not seeded
  • »29.07.06 - 12:16
    CISC
    Posts: 619 from 2005/8/27
    PRNG is not seeded.
    What is wrong?
    This means the port is broken and unable to get the required pseudo-random numbers...
    Then I suggest you check your spam settings (or if you're using GMX or some other service with broken spam rules; switch service!), if that's not the issue I guess you'll have to resubscribe (see the mail you got when you registered the first time). You should have gotten a delivery failure if your mail-service was working properly though.
    - CISC
  • »29.07.06 - 14:33
    March
    Posts: 91 from 2003/7/30
    You probably forgot to install yarandom-handler and RANDOM: device.
    Marek Szyprowski ...... happy MorphOS, AmigaOS and Debian/Linux user ........
  • »30.07.06 - 04:04
    Yvan
    Unfortunately not, it is installed and the test tool rndtest even shows some random output.
    I won't copy/paste it :)
    But I still get PRNG is not seeded
  • »30.07.06 - 16:11
    Yvan
    about the mailing list.
    I am using gmx, it never was a problem in the past. Is it not possible anymore to use GMX?
    It is not in the Spamfolder.
    And yes, I should have received a delivery failure notice I didn't.
  • »30.07.06 - 16:19
    CISC
    No, GMX is using a broken service that blocks all emails from what it perceives as dynamic addresses (and even tries to blackmail the owner of the SMTP), it is utterly and irrevocably useless (until someone can convince them to stop using this service), I urge you to complain to GMX and switch to another provider until they sort it out.
    - CISC
  • »30.07.06 - 18:45
