Posts: 481 from 2004/3/28
Ave!
I have a mac at home, and I'm using VNC to control it via the home network. On Mac there is OSX 10.4, and OSXvnc, on MorphOS side I use both TwinVNC and MorphVNC. I have some troubles with this config:
- Controlling the iMac G3 via VNC is incredibly slow (e.g. my account to a remote Windwos server via rdesktop (1Mbit connection, 1280x1024x16 bit resolution) is much faster than the local mac (100Mbit, 1024x768x8))
- Ctrl key from time to time appears to be pressed (without I've touched it)
- Keyboard layout is "very strange": If I set up hungarian layout both on mac and MOS, only the english letters and the alphanumeric numbers work correctly on the keyboard: all other keys are set to "very strange" letters: (E.g. all of the alphanumeric numbers with shift write an "Á", 0 is not found on the whole keyboard at all, nothing is in his place, etc.). Setting english on both sides makes a correct english layout, but I need the hungarian accented letters.
So... Does anybody know the solution for this problems? Maybe I shall use other VNC server (have tried RealVNC, and it is much worse...)?
[ GK / LKA Team ]
