PC105-se on Aminet?
    CISC
    Posts: 619 from 2005/8/27
    I'm abit curious about this since no-one reported any particular issues with it, and what's mentioned in the readme:
    This keymap properly supports the 105 swedish keyboards
    and also supports the amiga way of entering accented characters Alt-[F|G|H|J|K] and then pressing one of the following 'accentable' keys A,E,Y,U,I,O,N.
    already works .. so what exactly changed (if one should have any hope of getting whatever is wrong fixed in a future release)?
    - CISC
  • »24.07.06 - 09:40
    merko
    Posts: 328 from 2003/5/19
    Better mail the author/uploader. I used the default MOS 105-key
    Swedish keymap since the first Peg release, and I do regularly use
    these accents, and never experienced any problem.
  • »24.07.06 - 10:31
    CISC
    Well, I posted here because I know the author is signed up here, and because I want to know if anyone else has any issues, thus hopefully getting some useful debate on things... ;)
    - CISC
  • »24.07.06 - 10:45
    gunne
    Posts: 441 from 2003/2/25
    Its Beanbandit thats the author of this.
    I have not tried it, maybe should do :-)
    Best wishes, Gunne
  • »24.07.06 - 17:33
