    Triumph
    Posts: 49 from 2003/2/24
  • »09.08.03 - 07:44
    Posts: 1081 from 2003/3/24
    Wow W3D Support for Voodoo Cards, but no MPlayer!
  • »09.08.03 - 08:49
    DSLCC
    Posts: 246 from 2003/5/14
    Can't get in...they must have changed the password.
    Pegasos 1 G3 MorphOS 1.4.5* Mac G4 Sawtooth 1Ghz Tiger 10.4.1* Both Rock! :-D
  • »09.08.03 - 13:17
    Posts: 2 from 2003/6/22
    The server is full.. and has been for a few hours  :-(
    And i'm just missing 6MB of the file but can't log on to the ftp.
  • »09.08.03 - 13:40
    gunne
    Posts: 441 from 2003/2/25
    Maybe you can try again later. I have also considered to perhaps make it available on cd's together with the Super Bundle for they who are interrested in this.
    Cheers
    /Gunne
    Best wishes, Gunne
  • »09.08.03 - 14:46
    Posts: 20 from 2003/7/11
  • »09.08.03 - 14:58
    DSLCC
    Found out what was happening. Yam managed to mess up the email that I got telling me how to join the mailing list. :(
  • »10.08.03 - 18:24
  • HAK
    Posts: 225 from 2003/2/24
    @ Coder,
    Well, the size of the lha-file is 19505577 bytes.
    If you install it MOS 1.4 needs about 39 MByte on the HD.
    (If you install it over an existing MOS, MOSSYS: will be preserved
    which means an additional 20 MByte (depending on your old MOSSYS:).
    Bye HAK
  • »10.08.03 - 21:38
    Coder
    Posts: 296 from 2003/3/5
    @HAK
    Thnx for the info! I will get it when I am back from my holiday. Can you believe it that the minute I moved they had fast inet on my old place? The <beep>. Now I am still stuck with 56k. But I manage. Even though it takes weeks to get something, I WILL. :-)
    Looking forward to 1.4
    Coder
  • »10.08.03 - 21:44
    DSLCC
    Got it now! :) My reaction?? Awesome!!! Many great additions!!
    Installed smoothly, but I'm still playing with it. :-)
  • »11.08.03 - 15:46
