Posts: 2833 from 2003/2/7
				Unfortunately, this is part of the ambient works at boot-time.  As far as I can tell, these graphics are loaded at boot time.  If I can find a way to force Ambient to re-read the graphics while it's running, I will make a change to eliminate the reboot--I just have to find a command, function, etc for doing this.
Until then, please bear with me
