Posts: 315 from 2004/2/13
This was reported in a message on the morphos-mailing-list:
> can you print with other programms to C84. If print
> with the C82 driver good to C84.
Yes from EVERY program I can print but I print only
through PS: and I use GS850.
I use the C84 driver from TP 7.60 package which works
fine if it's that you want to know. BTW I tested the
newer Epson C86 and D88 and both printers work fine with
the C84 driver.
For such a low cost printer it gives me excellent
results, even print photos on glossy paper.
I have removed the name of the author for privacy reasons, but I have no doubt that he was reporting correct information.
