Kill an (hang)application
    Posts: 90 from 2003/4/13
    Hello,
    If an application 'hangs' I must reboot in most cases.
    It would be nice if I was able to kill that 'hanger' and no reboot :-) at all !!
    hgm :-?
  • »11.08.03 - 08:55
    Mekhet_
    Posts: 7 from 2003/5/20
    Hello,
    try to use scout.
    https://morph.zone/modules/mydownloads/singlefile.php?lid=10
  • »11.08.03 - 08:57
    Scout and all other similair application are not meant to do such a thing. And in the end scout itsself freezes.
    What I mean is a KILL application as it is on UNIX and Linux. :-( :-?
  • »11.08.03 - 09:02
    mahen
    Posts: 118 from 2003/2/24
    lowietje1 : it's impossible under AmigaOS / the A/Box.
    xmpp:mahen on jabber.fr
  • »11.08.03 - 09:31
    I am not talking about AmigaOS or A/Box but MOS native:-) The Quark kernel :-)
  • »11.08.03 - 09:34
    mahen
    ATM everything is under the A/Box (complete reimplementation & modernization of the AmigaOS API). MOS Native programs too. (native means they don't use the 68k emulator)
    What you want is the Q/Box which will take years to be completed (otherwise it's impossible due to the AmigaOS legacy / limitations) - just as under OS4.
    All this is connected to one of the main MOS / OS4 / AOS problems : no resource tracking. Also the fact that there's no real memory protection is the most annoying problem of the A/Box / AOS(4).
  • »11.08.03 - 09:37
