VICE 1.19 for MorphOS
    Piru
    Posts: 617 from 2003/2/24
    VICE (The Versatile Commodore Emulator: C64, C128, VIC20, PET, PLUS4 and CBM-II) was finally ported to AOS 3.x/MorphOS/AROS recently. However the initial MorphOS version was quite buggy, so I decided to fix the most serious bugs.
    My VICE MorphOS build:
    http://www.iki.fi/sintonen/vice/
    Original VICE port:
    http://www.amidog.se/amiga/vice/
    VICE home page:
    http://www.viceteam.org/
  • »24.05.06 - 06:42
    Toto
    Posts: 268 from 2003/4/20
    Hi Piru,
    Thanks, nice job. It works great and the PAL mode looks very nice fullscreen. Is it possible to turn off the statusbar in fullscreen mode?
    One thing, there's a problem with the joystick input, the left/right axis is reverse.
  • »24.05.06 - 08:11
    Piru
    AFAIK it's not.
    This was fixed yesterday already.
  • »24.05.06 - 09:11
    Toto
    AFAIK it's not.
    Ah, you're going too fast :-) I didn't realise you've already updated Vice, it works now, thanks.
  • »24.05.06 - 09:28
    magnetic
    Posts: 2129 from 2003/3/1
    Yay
    Thanks Piru..
    Is VICE better than FRODO??
    magnetic
  • »24.05.06 - 22:01
    hooligan
    Posts: 1948 from 2003/2/23
    Wayyyyy better.
  • »25.05.06 - 05:08
    warface
    Posts: 653 from 2003/2/24
    Wayyyyy better.
    Umm... Then I must give it a try.
  • »25.05.06 - 05:33
    analogkid
    Posts: 716 from 2004/11/3
    I hope it gets Overlay Support, because that's one thing I like very much in Frodo.
  • »25.05.06 - 05:41
    Crumb
    Posts: 736 from 2003/2/24
    @magnetic
    VICE is better (but I think that slower). VICE can show all special screenmodes found in some c64 demos that Frodo refuses to show
  • »25.05.06 - 09:04
    C64Days
    Posts: 103 from 2006/2/27
    Well done, could you remove the need for a running TCP/IP
    stack in the next release? It annoys me to have to launch
    Miami every time i want to watch a demo or try a game on Vice.
  • »25.05.06 - 16:40
    Piru
    @C64Days
    Fixed. bsdsocket.library is opened on demand now.
    Also, the network code now works somewhat (but only to another big endian 32bit system for now, there are still some endianity issues). It is experimental, so expect some problems with it.
  • »25.05.06 - 20:49
    dIGIMAN
    Posts: 273 from 2005/11/7
    Which Joystick do you people use?
    USB Version of Competition Pro?
    Is it supported?
  • »25.05.06 - 21:39
    magnetic
    According to Piru it supports lowlevel.device and Poseidon should work with it..
    magnetic
  • »26.05.06 - 02:52
    hooligan
    [/quote]
    Is it supported?
    [/quote]
    I have been playing with CPro for a couple days.. I got re-addicted to "Rockstar ate my hamster" ;-) ... the joystick works perfectly.
  • »26.05.06 - 05:32
    dIGIMAN
    Oh yeah, that Game is crazy, i loved it to.
    I will get a CPro then.
    Thanks m8 :)
  • »26.05.06 - 05:56
    Posts: 108 from 2005/4/3
    Forbidden Forrest, i can play the game since a while, great !
    Blue Max, Hunchback and others. However, not all games goes
    properly, Olympic Ski, Le Mans, the joystick do not work. Attack Of The
    Mutant Camels, black screen. I choose load and run. Nice to see
    the contents of a D64 disk or T64 tape in the fileload requester !
    Grts, Amigaharry
    http://www.angelfire.com/amiga/ex
  • »27.05.06 - 18:30
    C64Days
    Piru wrote:
    @C64Days
    Thanks! (very quick!), as a footnote for the next release, recognition.db from Ambient nightly builds opens the ".exe" files
    with a fileviewer instead of executing them (i know it's Ambient
    to blame), so if next time you remove the ".exe" file extension... :)
  • »27.05.06 - 20:53
    Piru
    New VICE build is out. Implemented overlay support now, and fixed more bugs.
    changes to previous version:
    - video.c/statusbar.c: Don't crash if some resources are not available.
    Use regular window instead of gimmezerozero one. MorphOS: For Pegasos
    fullscreen try depths in order 32, 24, 16 and 15, for Amiga: 16 and 15.
    Added title for the screen. Use IDCMP_SIZEVERIFY so we don't render over
    window borders. Fixed not to RectFill() over window border/outside of
    the screen. Remember old window position instead of always reopening at
    100, 100.
    - MorphOS: Added overlay support. There are some limitations in the
    support for now, "Double size" only works properly for windows that
    double both width and height. You can achieve the same by disabling
    "Double size" and manually resizing the window to double height. It
    should be easy to enable overlay for OS 3.x build aswell.
    - mousedrv.c: Fixed to properly process all input events in the list.
    Fixed to properly remove input events. Added Forbid() protection to
    avoid race conditions.
    - MorphOS: Fixed "1351 mouse emulation" inputhandler crash.
    - Now removes the "1351 mouse emulation" inputhandler when VICE quits.
    - C128 emulation: Fixed generic problem in VICE; multiple windows would
    corrupt each other's palette.
    - Fixed RGB to YCbCr conversion routine.
    - Fixed the custom file requester not to list RAM: among the initial
    directory contents.
    - Improved to open the possible system requesters to the same screen as
    VICE.
    - Fixed archdep_expand_path.
    - MorphOS: Removed statusbar from fullscreen mode.
    [ Edited by Piru on 2006/5/28 15:41 ]
    [ Edited by Piru on 2006/5/28 15:55 ]
  • »28.05.06 - 11:24
    Hi all,
    When joystick do nothing, i set in pulldown-menu only one
    joystick in "Settings/Joystick settings.../Joystick device selection"
    then "Joy 1 Device -> Joy Port 1" leaving the other empty.
    If the problem stays, do in pulldown-menu "Options/Swap Joystick"
    Olympic Ski, i can play it as of Pole Position too!
    Grts, Amigaharry, home of SimpleView, a MOS machinecoded viewer;
  • »28.05.06 - 15:52
    hooligan
    @Piru
    Big thanks for the update, overlay is appreciated
  • »29.05.06 - 01:27
    Hi all,
    3rd VICE release, i can play SuperCycle and Choplifter ! Thanks Piru.
    Grts, Amigaharry
  • »19.06.06 - 10:51
    C64Days
    This new release hosted on Amidog site, is done by Piru?
    Or by Amidog with the changes provided by Piru?
    Or entirely Amidog's work? Docs aren't helpful on
    this subject (and no changelog, sigh!)
  • »19.06.06 - 11:09
    http://www.amidog.com is this VICE from. Piru website, there're appears
    a VICE archives too. However, the archive name are the same. Saving the settings
    causes the next time starting up VICE with "x64.exe" window:
    network.c:192: failed assertion `server_port == tmp'
    Program aborted
    I inquired "vice.ini" file, which is the settings file inside the VICE drawer.
    Delete the file and VICE runs properly !
    Not all menu functions are implemented in VICE, i think that's the reason the
    settings-file aborts VICE.
    For sure, i'am happy with VICE.
    Grts, Amigaharry
  • »20.06.06 - 10:13
    C64Days
    It's a known bug on Windows version too, just hope it
    gets corrected in the original sources any soon.
    amigaharry wrote:
    Program aborted
    Grts, Amigaharry
  • »20.06.06 - 18:22
