Registration Problem
    Sir_Lucas
    Posts: 112 from 2006/4/23
    Hi to all,
    I've been trying recently to register my PUP Mos, but every time I try to do so I get the response that I'm either offline or the servers are off. Why is this so?
    My version comes from February 'cause the June "Satan" version doesn't boot on my A1200.
    Any ideas??
    Thx
  • »13.06.06 - 23:36
    CISC
    Posts: 619 from 2005/8/27
    Unfortunately the server is down ATM, it'll hopefully be fixed soon, patience please. :/
    Yep, we're working on that too, sorry about that, I guess we should make sure all the required nubile virgins are sacrificed before the next release. :P
    - CISC
  • »14.06.06 - 00:59
    Sir_Lucas
    OK, thx.
    Talking about nubile virgins, that would be a good a idea.
  • »14.06.06 - 08:38
    AmigaMancer
    Posts: 265 from 2005/8/25
    Aha! I knew that there was something evil in MorphOS!
    Amiga 1200 user.
  • »14.06.06 - 16:38
    Framiga
    Posts: 363 from 2003/7/11
    @CISC
    its the "Boot:rom/module.com1" that gives problems (probably modified/optimized/adapted for A4000T).
    Replaced with the previous version and the system (A4000D) starts correctly.
  • »14.06.06 - 19:33
    CISC
    Yep, we know, thank you for the report though. ;)
    Huh? Are you saying it doesn't work for A4k too? Chain|Q indicated otherwise... :P
    - CISC
  • »14.06.06 - 20:19
    Sir_Lucas
    Good to hear that you've found the mistake :)
    Thx a lot for the support and answering the questions :)
  • »14.06.06 - 21:07
    Framiga
    with the latest release3 plain "module.com1" my A4000D doesn't start at all.
    With the "module.com1.idehack" it starts. (or with the previous released plain module.com1)
    If you need further detalis, let me know.
    [ Edited by Framiga on 2006/6/14 22:14 ]
  • »14.06.06 - 21:11
